Old 09-22-2010, 01:49 PM
weezerboy weezerboy is offline
Default Moving Selection By Selection Length
I have a long region and a chunk of it is selected. I need to select the exact same size chunk of audio directly after the current selection. Is there a way to do this quickly? Sorry if its confusing... What I'm looking for is a lot like shift+/- but instead of moving the selection by the nudge value, I want to move the selection by the size of the current selection. Thanks in advance for any help!
Imac Late 2013 2.9 GHz Intel Core i5
8 GB 1600 MHz DDR3
OS 10.11.2
PT 12.4.0
Old 09-22-2010, 02:00 PM
2fly 2fly is offline
Default Re: Moving Selection By Selection Length
One way which would work is to First split the selection you've made (appleE) then duplicate your current selection (appleD) make a note of where the duplicate ends and then undo the duplicate and use the info to split the following audio.....
There might be a quicker way but that won't take long and will work
Alan
http://www.2flystudios.com
G5 2.5ppc, 4gb ram, OSX 10.5.8, PT8.0.1cs4
Old 09-22-2010, 02:08 PM
Stig Eliassen's Avatar
I've had to do this a few times, and did it like this:
  1. Create an empty "dummy track" below the one you're editing
  2. Make the selection in the original track
  3. Separate
  4. Hit ":" to go down to the dummy
  5. Repeat the empty selection 1 time
  6. Hit "P" to go back up to the original
  7. Rinse & Repeat
I'm sure there are better and faster ways to do this, which once again would make me go !!!
Old 09-22-2010, 02:17 PM
Thanks for the help! The dummy track idea is a little more efficient than what I was doing. A shortcut for this would be rad. I found this in a search but I need the tab to transient function...
From Rail Jon Rogut re: Can I nudge a selection so it starts at its end?
Disable Tab to Transient, copy the length by clicking in the Length field at the top of the Edit Window and copying it (Command+C)... after working on your first phrase separate the region Command+E (in your prefs enable Auto name separated regions) hit the Tab key and click in the Length field and paste the value (Command+V)(Return).
8 GB 1600 MHz DDR3
OS 10.11.2
PT 12.4.0
Old 09-22-2010, 02:28 PM
Richard901 Richard901 is offline
Move the selection forward by the selection amount
Command+Control+Option+Apostrophe (’)
Move the selection backward by the selection amount
Command+Control+Option+L
Hope this helps.
Richard
Pro Tools 2023.9
Ventura 13.6
Old 09-22-2010, 02:42 PM
Hope this helps.
Richard
Aha! Now that looks handy! I'll be trying that tomorrow.....excellent place the duc
Alan
Old 09-22-2010, 02:55 PM
Amazing! Command+Control+Option+L works for backward but I can't get Command+Control+Option+Apostrophe to work for forward. I've tried all sorts of similar combinations and none of them work. I'm using 8.0.3cs1... Can anybody get this shortcut to work?
8 GB 1600 MHz DDR3
OS 10.11.2
PT 12.4.0
Old 09-22-2010, 03:02 PM
The apostrophe key I'm using is to the left of the backslash.
I'm pressing ' NOT " (with shift).
My keys go -
K L ; ' \
Mine's a UK keyboard.
Richard
Pro Tools 2023.9
Ventura 13.6
Old 09-22-2010, 03:21 PM
Thanks for all the help Richard! My keys go (K) (L) ( ( ' ) (enter). I'm not sure why it's not working... I'll keep trying things out. I googled "Move the selection forward by the selection amount" and found this link where someone else mentions being able to move the selection backwards but not forwards.
http://duc.digidesign.com/showthread.php?t=266625
What version of pro tools is it working in for you?
8 GB 1600 MHz DDR3
OS 10.11.2
PT 12.4.0
Old 09-22-2010, 03:36 PM
Very strange!
At the moment I'm using M-Powered 8.0.3cs2.
I wonder whether it's a UK/US keyboard problem.
Just a wild guess - try the similar looking symbol (not sure what it's called) just below the ESCAPE key on a US keyboard
or
the 2 key
(the @ and " keys work the opposite way on a British PC keyboard compared to a Mac.)
Richard
Pro Tools 2023.9
Ventura 13.6
Hotkey for double/half length of selection jschmidtiii macOS 1 10-17-2013 02:20 AM
Playing back part of a selection without affecting timeline/selection jschmidtiii macOS 2 05-11-2013 01:05 PM
Default selection length MFPBand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-30-2012 04:09 PM
timecode selection length - Pro Tools lies! levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-20-2009 10:01 PM
moving a selection downwards not working mhmh Pro Tools TDM Systems (Mac) 3 06-01-2008 04:26 PM
