Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 04-20-2023, 03:32 AM
LukeHoward LukeHoward is offline
Default Re: MOMStreamDeckPlugin
Originally Posted by off the wall View Post
Thanks @lukehoward!
I just setup a Stream Deck+ with DADman and a MTRX Studio. So far so good. I got the basics going, now have to delve into the details.
One thing I noticed from the photo: if you setup the keycap labels from the plugin settings (rather than globally), you can replace A/B/C/1/2/3/etc with custom labels, and also have distinct labels for each layer.
https://lukehoward.com/
Old 04-20-2023, 07:54 AM
off the wall's Avatar
off the wall off the wall is offline
Thanks! Yes I have already done that. It's been an evolving process over the past two days. :)
I've got three layers going so far - Control Room, Headphones 1, Headphones 2.
I'm currently trying to setup a "Surround" layer where I can solo/cut each speaker, etc. That is proving to be a bit of a mind game with the DADman part. :)
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 04-20-2023, 08:06 AM
Two approaches for this: create a fold down with some speakers absent, or a new output with some absent.
Old 04-20-2023, 08:17 AM
Thanks, good tip on the FoldDown. I've been messing with the latter approach with a lot of unexpected results.
Old 04-20-2023, 08:27 AM
I actually use the latter approach because I didn't think of the fold down approach and it's fine, except it's a bit more error prone setting up because you need to copy all the EQ and trim settings from the main output. Fold downs you can simply just leave the unused speakers absent (as distinct from 0dB, of course).
DADman is powerful but not always obvious.
  #16
Old 04-20-2023, 02:22 PM
TrentWilliams TrentWilliams is offline
How do you get to the plugin settings?
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
  #17
Old 04-20-2023, 02:39 PM
Open the StreamDeck app from the menu bar, select a button and select the tab for the layer you wish to edit. On a plane otherwise I’d make a screenshot.
  #18
Old 04-20-2023, 04:30 PM
smh .. lol - first time I tried editing this nothing happened, working now.
  #19
Old 04-20-2023, 05:21 PM
BScout BScout is offline
I had an easy time doing this. Here's how I have it setup:
and then in DADman layer
Solo/mute (actually element active/inactive) is under Monitor set > Output Set > and then you get the individual speaker options.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
  #20
Old 04-20-2023, 06:48 PM
I got the surround speaker solos setup like I wanted using the Fold down method. Worked great. thx again Luke!
File Type: jpg Screen Shot 2023-04-20 at 9.38.57 PM.jpg (23.9 KB, 0 views)
File Type: jpg Screen Shot 2023-04-20 at 9.39.16 PM.jpg (30.1 KB, 0 views)
