Old 10-18-2021, 11:30 AM
jeff1s jeff1s is offline
Default MIDI Edit Windo stuck Behind Title Bar
Hello Everybody,
This started with a session from another user. I have trashed prefs, updated PT, I've Scaled display percentage, minimized and maximized Windows in and out of PT. Once this started, it has happened in every session since.
Any help will be greatly appreciated.
Sincerely,
Jeff
Old 10-18-2021, 11:37 AM
Tweakhead Tweakhead is offline
Default Re: MIDI Edit Windo stuck Behind Title Bar
even older sessions of your own creation ?
if not, open one of those sessions, save a Window Config with the MIDI window in a proper location, save the session and name it "Corrected Window Locations" or something. import only that Window Config session data into your new sessions.
if none of that works, sometimes grabbing a window by the very far borders allows you to move it.
then resize it slightly to update the metadata.
then save a Window Config so you can perform a reset even if it screws up again.
Old 10-19-2021, 09:13 AM
I worked with Jeff over the phone on this and we tried all your suggestions without success. Any other ideas?
Old 10-19-2021, 09:20 AM
bummer. change the resolution of the monitor to reset the window positions ?
Old 10-21-2021, 04:27 PM
A great idea, but sadly, it didn't solve the issue.
Old 10-22-2021, 08:02 AM
daeron80 daeron80 is offline
This happened to me once. I solved it by messing with the windows, but don't remember the exact thing that worked. It was something like, make the main PT window smaller, drag it down so the top of the main PT window is in the middle of the display, then maximize it. Or maybe instead of maximize, it involved using the horizontal dragger to raise the edge of the main window without moving anything inside it. Something like that. Good luck.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-22-2021, 08:13 AM
studiostuff studiostuff is offline
Have you tried another keyboard...?
Old 10-22-2021, 08:23 AM
One of the PT dropdown menus has an option to cascade windows.
Edit Window is stuck! Can't minimize or maximize. Please help! automatic8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-13-2021 03:23 AM
A Way To Edit The Title??? bredo Eleven Rack 1 04-21-2016 06:06 AM
Midi edit window stuck to edit window lvsranch Pro Tools 11 7 04-04-2015 12:42 PM
Tracks Stuck as Hidden in Edit Window only?! reichman Pro Tools TDM Systems (Mac) 3 10-16-2008 09:19 AM
