Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 08-14-2021, 01:49 PM
bonkmp bonkmp is offline
Default Protools first won’t load after downloading plugins
I installed Protools first with the link from my purchase of Focusrite 8i6 3rd generation and everything worked. I then downloaded the free Focusrite plugins and once again it launched. I then followed the link for the ProTools focusrite creative pack download, downloaded all the plug-ins listed on the page, some opened and some didn’t, and the ones that unpacked I installed. Now when I launch pro tools it hangs up when it is scanning plug-ins. I have to do you use force quit to get out of the program as it is not responding. I am using a MacBook Pro with iOS 11.4 with anM1 processor. Any help would be appreciated, at this point I have no recording capabilities. Thanks, Marty
Old 08-14-2021, 01:59 PM
Netmania Netmania is offline
Default Re: Protools first won’t load after downloading plugins
Hello and welcome,
i also use an M1 Macbook Air and the Focusrite Pro Tools First Version. On my system it scans about 2 minutes - every time. Seems to hang, but it doesn't. After a while everything goes on.
So please be patient. Other option is to look, if there are new versions - especially for the Focusrite creative plugins. Please note: Only Addictive Keys, Softube Time and Tone Bundle and The RED Plug-ins will work other than that the Eleven Effects Bundle, Eleven Lite, Xpand2 and UVI Workstation.
Hope that helps a bit.
Best
MacBook Air M1, 8 Gb, 512 GB Apple SSD, 512 Gb Samsung Evo 970 NvME TB3 SSD, 1000 GB Crucial P1 TB3 SSD, macOs 12.3., RME Babyface blue,
macOs Sonoma 14.4.1
MacBook Pro 13, Mid 2012, 16 GB, 250 GB Crucial MX
macOs Sonoma 14.4.1 / Windows 11
_____________________________________________
Pro Tools 2022.7
Logic Pro 10.8.1
Cubase 12.07 Elements
Wavelab 11.2 Elements
Music was my first love - shine on
Old 08-15-2021, 07:13 AM
Thank you for the reply, I waited for 20 minutes or so and when I used force quit it said protools wasn’t responding.
Old 08-15-2021, 07:27 AM
1.What Version of Pro Tools First did you install?
2.Please open Macintosh HD(your Maindrive) - Library/Application Support/Avid/Audio/Plugins and show me what plugins are loaded.
Meanwhile i was fortunate with sorting out plugins that Pro Tools First don't use to bring my boot uptime to nearly 1 Minute
Everything should work, if you are on Pro Tools First 2021.6 and all your plugins from Focusrite are registered in your ilok license manager.
Best
macOs Sonoma 14.4.1
Pro Tools 2022.7
Logic Pro 10.8.1
Old 08-15-2021, 07:46 AM
If the problem persists - please follow the instructions on the Focusrite Support site
https://support.focusrite.com/hc/en-...Creative-Pack-
Best
macOs Sonoma 14.4.1
Pro Tools 2022.7
Logic Pro 10.8.1
Old 08-15-2021, 12:35 PM
Thanks, this is the list and I suspect one is causing the hangup because several would not open when I downloaded them and yet they're showing here. I'm going to remove them and see what happens. As far as I know the current version is updated because I downloaded it this past week. The Focusrite plugins worked and I like the EQ a lot.
BBD Delay.aaxplugin
Black Op Distortion.aaxplugin
Black Shiny Wah.aaxplugin
Black Spring.aaxplugin
C1 Chorus.aaxplugin
ClickII.aaxplugin
DC Distortion.aaxplugin
Dither.aaxplugin
DVerb.aaxplugin
DynamicsIII.aaxplugin
Eleven Lite.aaxplugin
EQIII.aaxplugin
Flanger.aaxplugin
Graphic EQ.aaxplugin
Gray Compressor.aaxplugin
Green JRC Overdrive.aaxplugin
InTune.aaxplugin
Invert-Duplicate.aaxplugin
ModDelay_III.aaxplugin
Normalize-Gain.aaxplugin
Orange Phaser.aaxplugin
Red 2 EQ.aaxplugin
Red 3 Compressor.aaxplugin
Reverse-DC Removal.aaxplugin
Roto Speaker.aaxplugin
SciFi.aaxplugin
SignalGenerator.aaxplugin
Studio Reverb.aaxplugin
Tape Echo.aaxplugin
Time Shift.aaxplugin
TimeAdjuster.aaxplugin
Tri-Knob Fuzz.aaxplugin
Trim.aaxplugin
VariFi.aaxplugin
Vibe Phaser.aaxplugin
White Boost.aaxplugin
Xpand!2.aaxplugin
Old 08-15-2021, 12:52 PM
I removed all the plug-ins and it works so apparently one or more are causing the conflict. If you happen to notice from the list any that are problematic please let me know, I am going to reload the focusrite red because I know there’s no problem there. Your help was greatly appreciated. Marty
Old 08-15-2021, 01:40 PM
Hi Marty,
as far as i can see all plugins are legit and should work. Sometimes plugins from AIR make problems with newer Mac Os. Please visit AIR Music Tech and download the newest version of XPandII for Big Sur.
Best
Michael
macOs Sonoma 14.4.1
Pro Tools 2022.7
Logic Pro 10.8.1
Old 09-02-2021, 10:15 PM
rademusic's Avatar
rademusic rademusic is offline
I've been having the same issue as you when Eleven Lite is in my plug-ins folder. When I take it out, PT loads and doesn't crash anymore. Maybe it's that one?
rademusic.bandcamp.com
MacBook Air M1 2020 8GB RAM Big Sur 11.4
Pro Tools | First 2021.6.0
M-Audio Fast Track USB
M-Audio BX3 Studio Monitors
Old 10-01-2021, 01:24 AM
rademusic's Avatar
I've also found that my PT First won't load with InTune in my plug-ins folder either
Help Downloading TAL Plugins ethandla macOS 7 11-05-2016 04:58 AM
about downloading a VST plugins for protools 9 / Windows 7 stiphane Pro Tools 9 6 12-08-2013 11:48 AM
Pro Tools 10 not load plugins,freezing load.HELP javierboz Windows 2 11-08-2012 04:25 AM
Protools Freezing on load up/ plugins. Apolloape macOS 5 10-24-2012 05:11 AM
downloading plugins mandyt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2007 01:02 PM
