Old 01-20-2008, 09:07 AM
M2E M2E is offline
Default Anyone have Pro Tools shortcuts in Logic Pro 8?
I don't want to have to do all the shortcuts manually. Does anyone know how I can get them?
Thanx
Marc
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies)
YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc
Old 01-20-2008, 10:09 AM
TCDet TCDet is offline
Default Re: Anyone have Pro Tools shortcuts in Logic Pro 8?
Change in logic prefs .re- Run the set up and select pro tools.
I myself prefer to know them both.
At least you could do this in 7.2.3 I balked at LS8.
Old 01-20-2008, 11:34 PM
M2E M2E is offline
I know....I liked that in Logic 7 but, in Logic 8 they don't have that anymore.
Anyone else???
Marc
Old 01-21-2008, 02:21 PM
David Pye David Pye is offline
You can do it in LP7 and then import those key commands into LP8.
The only problem is that some of the commands don't match up between 7 and 8, so they won't transfer.
Old 01-21-2008, 10:26 PM
M2E M2E is offline
Anyone using them in LP8 and care to share the luv?
Thanx
Marc
Old 01-24-2008, 12:42 AM
scottgreiner scottgreiner is offline
I was looking for the same thing about a month ago - didn't find anything.
I started fiddling around with Logic8 for fun, but found the difference in key commands a real buzz-kill. I spend so much time in Protools (since the beginning) that my fingers just do their thing. I couldn't even tell you what the keystrokes are! It's nice to have the mundane [bleep] be on auto-pilot so I can use my limited brain power for more important/creative things.
If I find it, I'll post it.
Old 01-24-2008, 11:19 AM
M2E M2E is offline
Thanx, also, if I find them I will share as well.
Marc
Best Pro Tools Shortcuts TrentWilliams macOS 1 10-27-2013 09:27 PM
Special Shortcuts for Pro Tools? pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 02-08-2009 05:42 PM
Protools Shortcuts in Logic key commands? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-01-2006 05:57 AM
Logic using Protools Shortcuts? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-22-2006 10:26 AM
Pro Tools Shortcuts in Logic Pro ? Nad4 Pro Tools TDM Systems (Mac) 7 08-24-2005 05:40 AM
