BEAT DETECTIVE
I'm wanting to beat-mix music tracks,and am currently trying to use beat detective,to try and shift the beats to the bpm of the previouse track with zero luck.Beat detective struggles to locate & cut the beats cleanly.Not a dj but still trying any suggestions or alternatives.
Re: BEAT DETECTIVE
Yes BD does sometimes struggle unless you give him clues, so a close reading of the manual on pages 283-286 should help- the 'tips for getting useful triggers bit' esp. Also make sure that you exp. with sub beats selected and choosing whether there are 32nd notes and triplets. Try hi-emphasis and low emphasis whatever works best...it's really a matter of tweaking away until you get there sometimes. Hope that helps, Irene |
Re: BEAT DETECTIVE
Beat Detective does work!
It may take some experimenting as Irene said but it will be worth it in the end. I had to read the manual several times and experimented with many settings before I realized its potential. It has made bad drummers acceptable and great drummers even better. I love it! Don'tgive up and good luck. |
Beat Detective/Quantize Swing Beat | anackman | macOS | 1 | 10-15-2012 07:10 AM |
Tempo mapping Beat Detective or identify beat? | grateful | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-14-2012 09:13 PM |
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! | Robbry | Pro Tools M-Powered (Win) | 0 | 02-24-2010 02:14 PM |
what do grid lines do after beat detective bar-beat markers | cc1 | Pro Tools TDM Systems (Mac) | 1 | 05-22-2007 09:34 AM |
Beat Detective, Beat markers to Tempo Ruler?!? | phobia | Tips & Tricks | 3 | 01-01-2007 01:31 PM |
