Recording with a microphone
Hi
I would like to record my Upright bass without using headphones. but have the problem of feedback. I was able to go into preferences and enable mute record-armed tracks while stopped, but as soon as I start play/record on my bass track I get feedback through my monitors. I am using carbon which is connected to my console and routing the bass into a channel on the board via carbon mic input. Is there anyway to have this track automatically mute upon starting play/record. Thanks Tony Protools 2023 ultimate Mac M2 studio Tac Scorpion board Neumann KH monitors |
Re: Recording with a microphone
With your monitors on, anything playing thru them is also going to end up on your bass track. If you can hear it, so does the mic. Path of least resistance is either use your phones or a pickup. IMHO.
You might want to give significantly more detail and a more accurate description of your signal flow, and work flow method and why you are trying to use the speakers ?? "Signal flow description " wise ,,,,, as far as I know, you cannot "routing the bass into a channel on the board via carbon mic input." given a "carbon mic input" is just that, an "Input",,, and cannot be used to output to a mixing console channel ???????? However for example you can run a mic for the bass into a Carbon mic input, have that mic input be the input for a bass track in PT. Then you could route the output of that bass track into a channel on the console via the DB25 analog line output on the Carbon Then route from the Console back into the Carbon via the DB25 analog line in Not clear why you would do that , or what that would accomplish ?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
I am also suggesting using headphones is the path of least resistance. Having said that, IF(the big "if") you don't mind bleed into the bass track(assuming you are trying to play with other instruments already recorded), you could simply mute the bass track while recording(it will still record just fine).
Why are you opposed to headphones? If its a comfort factor, maybe switching to some earbuds might be a solution(but probably not wireless or Bluetooth due to possible latency). In my Nashville studio, I had several players that would bring their in-ear monitors to use instead of headphones
It's simple, all I want to do is record a track with a mic with the monitors on, but have that track muted to the monitors when recording, then on playback the track would be unmuted. I don't know if this is possible LOL
It's just I want to record my bass without headphones, and not have to mute my board whenever I hit record. Thanks for replying. |
Check out muteomatic from Sound Radix. It's free.
Even tho it's not written for your special scenario, I think it should work for you. |
Recording 101. |
If you can hear your upright acoustically, why not just mute the recorded channel so it is not going to monitors?
I think they don't want the muting 'hustle' and just hit play and hear the recording, or record and don't hear the signal going through the mic.
I'm quite sure there isn't a playback involved either. Wouldn't make sense at all. Like I said, check out muteomatic, it can be set to mute while in record and unmute while in playback. Edit: Load the plug-in onto your record track and set it up as shown on the attached image and you should be good. |
In Setup, unlink Play and Record Faders. Leave the Play Fader on your Track at Zero. Arm the Track and pull the Record Fader to the bottom. When the Track is in Play, you will hear what's on the Track. When the Track is in Record, no signal will pass out of the Track, but your signal will be recorded.
MICROPHONE RECORDING HELP!!! | Dennis O | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-11-2008 01:26 PM |
Microphone recording HELP!!!!! | confusion101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 07-26-2007 06:15 AM |
I/O setup/microphone recording | afterlife51 | Pro Tools M-Powered (Win) | 7 | 03-11-2007 09:35 PM |
let me know the best microphone vocal recording | JOAN ROSALES | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-24-2005 09:57 AM |
microphone(s) for stereo fx recording? | friendlybunny | Post - Surround - Video | 20 | 07-08-2004 09:09 PM |
