Pop/Click Every 5 Seconds After Bounce
I have been using ProTools for years now and have been working on this one song for the past couple of months. It has been bouncing fine until just recently. No updates or major changes to OS or ProTools versions, just the normal mixing, etc... All of a sudden, now, I noticed a slight pop/click in the audio after bouncing. And after further investigation, I realize that it is occurring every 5 seconds exactly! I have tried to adjust settings, and nothing has changed it. Does anyone have any idea what could be causing this?
Re: Pop/Click Every 5 Seconds After Bounce
Hi welcome to DUC.
Does this change if you bounce online or offline? If you commit tracks before bouncing? |
It does not change if set the setting in bounce to bounce after or during.
I have no idea what you are talking about.
The question was about online vs. offline bounce. (i.e the online check box in the bounce dialog). |
I believe you're referring to settings that I don't have. I use ProTools 8.0.5. The settings you're referring to I believe are in later versions. I don't have a checkbox for online or offline during bounce and I don't have options to commit tracks. These are all features I believe in 11 or later.
Would have been nice for you to say in your original post, yes I see it in your profile now but they don't get checked by many of us/are often out of date/useless. Read "help us help you" up the top of each DUC web page to see the kind of info you are expected to provide here.
And you posted to the wrong forum area, old legacy stuff should go elsewhere, there is no Pro Tools 8 section, it's so old but, Pro Tools 9 is close. https://duc.avid.com/forumdisplay.php?f=50 Please do **not** post a duplicate thread there now, maybe a moderator can move this thread. You should confirm if the clicks are really in the bounced file and not happening on playback, listen to the bounce file with another audio player. When you re-import the audio into Pro Tools do you see the clicks in the waveform? If you have ignore errors enabled, don't. Set your H/W buffer size as large as possible. Make sure no plugins are unlicensed/in demo mode and deliberately producing clicks. Make sure you are bouncing the source you expect you are and that you are monitoring that when listing in playback (to compare the same source). Check very carefully that the clicks are not in the standard playback (or even recorded in one of the tracks). Make sure there are no clocking issues, ideally you have one interface and its the clock source. |
The clicks are not in the playback, only in the bounced file. I have listened to the playbook over and over to see if I can find these, but they are not there....only in the bounced file. |
Gotcha, just make sure you are looking at exactly the source you are bouncing, folks sometimes accidentally bounce something else than they are listening to on the monitors, it might have other hidden tracks in it etc.
Offline Bounce adds 60 seconds silence to every song | 12StringJ | Pro Tools 2018 | 9 | 10-07-2018 08:22 PM |
Click track drops out during bounce | stevenj | Pro Tools 10 | 2 | 05-09-2017 08:48 AM |
cut out 4 seconds - now I have a click | sambeau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-29-2008 04:32 PM |
click or pop at end of bounce for CD burn bug returns in v7 | tapani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-13-2007 04:54 AM |
click at the end of bounce to disc-Digidesign HELP!!! | 1Nation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 04-04-2003 12:03 AM |
