  #6911
Old 10-25-2021, 05:23 AM
Sidecut Sidecut is offline
Default Re: i7 Builds - Specs and Results
Thanks EGS
  #6912
Old 10-29-2021, 07:33 PM
zedhed's Avatar
zedhed zedhed is offline
Originally Posted by EGS View Post
Hi all. Another new working Windows 10 Pro Tools build as of June 2021:
CPU: Intel i9-11900K
motherboard: Gigabyte Z590 Vision D
Ram: Crucial 64GB DDR4 3600
Running all cores @ 5.1 GHz
Works!!!
Hi @EGS
I'm in the process of looking at a new build and yours looks similar to what I'm thinking about.
So far I've narrowed it down to the following;
Motherboard: Gigabyte Z690 AERO D
CPU: Intel i9 12900K
RAM: (Haven't decided on Brand ) 64gb DDR5
My question is, in both the opposing (same brand) Motherboard & CPU's of the same specs, the difference is one has integrated graphics and the other does not.
I know integrated graphics has been a problem in some builds, are you aware if this is still the case or is that a thing of the past?
It looks like your build does have integrated graphics, is that correct?
Too much blood in my drugstream
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
  #6913
Old 10-30-2021, 08:52 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by zedhed View Post
Hi @EGS
K vs KF? My K has integrated graphics, but I use a dedicated NVidea GPU instead. I could've saved a few bucks with KF, but opted for K (as a backup). https://www.intel.com/content/www/us...057824/graphic
Your build will likely be a power monster that should future-proof you for a good while!
Click for audio/video demo
Click for resume
  #6914
Old 11-01-2021, 04:16 PM
zedhed's Avatar
Thanks EGS, I think I'll be good with the parts I've chosen then.
Yes indeed it will.
It's going to take a few months to buy/gather everything needed. It'll probably be end Feb next year before it's up & running.
HD 96I/O
  #6915
Old 11-01-2021, 10:10 PM
EGS's Avatar
EGS EGS is offline
Yes indeed it will.
Great. Let us know how it works for you.
Click for resume
  #6916
Old 11-02-2021, 03:03 PM
zedhed's Avatar
Will do.
I suspect it'll be little different from your build as far as performance goes.
HD 96I/O
  #6917
Old 11-03-2021, 03:09 PM
EGS's Avatar
EGS EGS is offline
To zedhed (& others doing Intel/Gigabyte builds):
When I first setup my i9-11900K/Z590 Vision D, I followed this article's straightforward advice: https://skatterbencher.com/2021/04/0...d-to-5500-mhz/
Scroll down to "Strategy #2: Traditional Approach". Worked perfectly first try, and running all cores at a constant 5.1GHz ever since. Temps are fine, no throttling up or down, no crashes. This is a conservative/gentle setting; no crazy "gamer" type OC stuff at all. Stable & works great 5 months in. This build has tons of CPU headroom.
Click for resume
  #6918
Old 11-05-2021, 02:15 AM
Skwaidu Skwaidu is offline
i9-12900K parts on the way here, wish me luck! The MSI PZ690-A Pro *looks* like it can handle my HDX2 cards...
(Biggest immediate worry I have is when Noctua will get around to shipping the LGA1700 adapter for my NH-D15)
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #6919
Old 11-13-2021, 05:51 PM
fiddlecat's Avatar
fiddlecat fiddlecat is offline
It's time! I am starting the process of configuring a new Windows system. My current system meets my needs just fine, no performance issues. But I have the cash, the time and the energy right now, so I would like to build a stable, “future-proof” system to take advantage of Windows 11.
I seldom record more than a half-dozen tracks at a time (think bluegrass bands). Editing and mixing maybe twice that number. Plugin and VI usage is very modest. No over-clocking or other “hot rodding” on the hardware.
My current configuration:
• Core i7-3820 CPU @ 3.60GHz
• ASUS P9X79 Deluxe motherboard
• 16.0 GB RAM
• Single(!) Samsung 860 EVO SSD (1TB partitioned half/half as OS and data) w/ second SATA or external USB/SATA drive as needed
Questions / Considerations:
• Is there any significant downside to going with an i5 CPU rather than an i7 or i9?
• Do ASUS motherboards still have a good reputation? If so, which series? (Prime, Workstation, or ??? So many choices!).
• Any thoughts regarding M.2 for the OS, or can I stick with my current 2.5-inch SATA drives?
• Although 16GB RAM has worked fine up till now, I will probably go to 32GB “just because”.
• I’m a very much out of date regarding i/o. What’s important on the motherboard? USB type C? USB 3.2? Thunderbolt?
Pro Tools 2023.6 & 10.3.0
Windows 11 Professional / 64-bit
Roland Octa-Capture
  #6920
Old 11-13-2021, 09:52 PM
EGS's Avatar
EGS EGS is offline
The 12th gen i5 is great! If going with 10th or 11th gen, though, skip i5 and go i7 or i9.
Dunno. I've had good luck with Gigabyte.
If you want to save some cash, then use your current SATA drives. Enable Pro Tools' disk cache, and you can use any drive. If starting from scratch or want the best, get M.2.
Good idea to go 32GB.
Depends on your audio interface, but a MB with Thunderbolt and USB 3.2 is a good choice for future-proofing.
Click for resume
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
