Digitest and Tiger problem
I just installed Tiger but can't run Digitest. Get "DSI error occured: -1092". Reseated cards, sessions open fine.
Re: Digitest and Tiger problem
Rebooted in 10.3.8 and Digitest runs and opens no problem. Doesn't run in 10.4.1 on a Dual 2.7.
I checked and I get the same error here with a Dual 2.5, 10.4.1 and 6.9.2 installed.
- Jason |
Same here. Running on both a PowerBook 1Ghz, 1Gb RAM, 6.9.2, Tiger 10.4.1, with a Magma PCI expansion chassis, and on a Dual 450 Mhz PowerMac. ProTools HD2, 192 I/Os. Same error on both machines.
There have been a few posts now re this Digitest error in 6.9.2 and Tiger. Sessions open and play OK.
Just thought I'd bump up the solution I found ie re-installing Digitest again from the disk image. Go into installer and select only this as an option - not the whole lot. (ie ProTools Utilities only - deselect everything else) I had already done the whole utility and Digi Database/prefs trashing etc, re-seated cards, flex cables etc but this solved this DSI Error -1092 for me. Hope this helps |
I also have been getting DSI Error -1092 running Digitest with PT TDM 6.9.2 installed on a dual 2.7 GHz and OS X 10.4. Then I tried reinstalling just Pro Tools Utilities from the 6.9.2 disk image but this didn't help. I also upgraded OS X to 10.4.1, but still no change.
Allan
Music: The Universal Language of Compassion and Inspiration 16GB MacBook Air 2020 Intel, MacOS 10.15.7, PT 2020.12; 2.8 GHz Core i7 16GB MacBook Pro 2014, MacOS 10.14.6, Thunderbolt Native/PTU 2020.5; 3.4 GHz Xeon 3-1270 Quad 16GB HP Z210 Win 7x64 SP1 & HD2 Accel/PTHD 10.3.10 or Digi 002/PT 12.4 |
Pro Tools Le/Tiger 10.4 Problem | CrassZorro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-18-2010 07:55 PM |
Undescribed Problem with PT 7.3 + Tiger 10.4.10 | herchinez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-21-2008 03:27 PM |
is this a TIGER vrs 9.2 problem? | ventjw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-31-2005 10:12 PM |
DigiTest Error 22 and 50 + Expansion Chassis Fan Problem | bowtieman | Pro Tools TDM Systems (Mac) | 0 | 04-04-2003 01:02 PM |
Problem setting up HD: Digitest fails flex cable test | uno1234 | Pro Tools TDM Systems (Mac) | 1 | 03-03-2002 04:41 PM |
