Old 07-18-2021, 11:00 PM
Soleille974 Soleille974 is offline
Default Sound stops...
Hello, :)
I have a problem with Protools (11.3) becoming mute after a few minutes.
When I use Protools, after some time the sound stops on it's own : Protools continues playing the music but it is muted (no sound). This happens when the file is lasting about 5 minutes.
The same problem happens if I don't use Protools for a few minutes : after some time, I clik on the Play button and it plays, but there is no more sound.
I need to restart Windows to be able to hear the sound again. But of course, after a few minutes, there is no more sound...
What can I do to fix ths ?
I use Fast Track Duo.
My system is Windows 8.
Thank you. :)
Old 07-19-2021, 08:13 AM
Default Re: Sound stops...
Hmmm, here are some things to check:
1-(really important since you have a USB interface) Disable Power Management on all USB ports(aka "USB Root hub" in Device Manager)
2-Set Windows Sound Properties so that Windows is NOT using the interface as its "default playback device"(set that to the on-board sound card)
3-(in case the above doesn't help), have you restarted the song? Just wondering if you somehow added automation(accidentally) that is either muting or dropping the master fader(assuming you have a Master Track in your session to check)
4-do your speakers have a "sleep" feature? If you listen at low volume, maybe the speakers are going to sleep?
Sound suddenly stops JerryA Pro Tools 11 29 07-31-2015 03:09 PM
mbox 2 sound stops harryk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-14-2007 04:18 PM
Sound Stops *DELETED* harryk MIDI 0 12-08-2007 05:24 PM
HELP - Sound Stops with MBOX TrackMaster Rick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-14-2006 10:48 AM
m-box sound stops playing S.p.Z 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-03-2005 08:27 AM
