Pro Tools ran out of X byte tokens
Everytime I do anything..... click, keystroke..... I get 1 of 3 messages...
Pro Tools ran out of 4 byte tokens or Pro Tools ran out of 8 byte tokens or Pro Tools ran out of 32 byte tokens Tech sup had me create a tex file in the ProTools app folder with the followig contents... Size:Count1 4:1000 Size:Count1 8:1000 Size:Count1 32:1000 Size:Count1 82:1000 I dont have a control surface, this isnt the 82byte token problem No Luck anybosy have any ideas Im dead in the water right now
HF |
Re: Pro Tools ran out of X byte tokens
Hi
Do you have any waves! i see this occasionally when i'm saving a waves patch! not directly related i know but worth a mention! Have you tried running PT with all plugs removed from the plugs folder, except the stereo. mixer.dpm plug!! as it might be a plugin issue?? Have you done the usual troubleshooting stuff? trash all prefs and data base files etc! http://duc.digidesign.com/showflat.p...fpart=1#177661 Re-install of Pro tools!? Run Digi test? Chris
im starting to think it is the hard drive my client brought in. I can open previous sessions and create new ones with no error. As soon as I copy or imprt anything from the drive in question token byte errors start. Luckily they had another duplicate drive which we copied session sfrom and problem has gone......for now.
Plug-ins are not the issue and I have trashed all prefs and Digisetup files many times. The sessions on the drive in question were using sd2 files. I did notice when i first plugged in the drive and didnt think anything of it that PT would not let me use that drive as a Recors or Playback drive. Transfer only. I wasnt planning on using that drive anyways....
HF |
Pro Tools ran out of 82 byte tokens | tpthai2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-12-2009 06:38 AM |
What does "Pro tools has run out of 82 byte tokens" mean? | piwacquet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-26-2007 07:09 PM |
Pro Tools ran out of 82 byte tokens? | Haggis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-20-2006 11:42 PM |
pro tools ran out of 82 byte tokens? then crashes! | crizdee | Pro Tools TDM Systems (Mac) | 4 | 08-16-2005 03:57 PM |
Pro Tools ran out of 82 byte tokens error | webnuts4u2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-04-2004 06:13 AM |
