Old 05-18-2022, 11:30 AM
Digital1 Digital1 is offline
Default Occasional mis-sample on print track
Our studio uses a print track internally within our Pro Tools sessions so that we can QC our mixes in real time before client delivery.
Recently, we have noticed our prints creating a “blip” right at the end of spots. This happens inconsistently and fairly infrequently, but it is enough that our clients have noticed and reported the issue to us.
In the last one or two samples of a selected region to be printed, the print track will randomly pull audio from earlier in our spot, despite every track being routed into the print being completely faded out by this point. I am completely sure there are no other hidden tracks causing this final blip, especially because the issue can be solved by changing nothing within the session and simply printing the same region again, non-destructively even.
Has anyone experienced this before?
I can grab some screenshots if that would help anyone understand better.
Pro Tools Ultimate 2021.12
MacOS 10.14.16
2 x 2.4 GHz 6-Core Intel Xeon
32 GB 1333 MHz DDR3
Old 05-18-2022, 11:44 AM
Top Jimmy's Avatar
Default Re: Occasional mis-sample on print track
Have you done the usual prefs and databases trashing?
James Cadwallader
Old 05-18-2022, 06:21 PM
smurfyou smurfyou is offline
Are you printing real time? Or offline and importing to the tracks? I almost always do it offline now and place onto the print tracks for playback. I have not had this issue.
If it's real time do you have any post-roll?
~Will
Old 05-18-2022, 09:02 PM
wwittman wwittman is offline
is there a master fader with a hard fade to zero at the end of the region?
if not, I would try that
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 05-19-2022, 08:44 AM
My suggestion as well, or if you can pin it to a certain track, fade that one. Where I have seen this is when my master track fades out, but snaps back slightly before the actual end of the bounce, causing a reverb tail to jump back in. If the fade out stays out for an extra second or two, that usually solves it.
Alternately, if you're going to export your print, put a short fade at the end(or beginning) and consolidate before the export.
Occasional mis-sample on print track Digital1 Pro Tools 0 04-20-2022 01:01 PM
Print audio from Midi Track (not Instrument Track) hardcase macOS 32 10-08-2015 05:51 AM
Occasional digital distortion on a recorded track on 9.05 SteveBoker Pro Tools 9 11 10-22-2011 09:14 PM
Occasional Static/Hiss from M-Audio Fast Track evenyre Pro Tools M-Powered (Mac) 0 06-05-2009 01:47 PM
How To "Print" Track? tikboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-30-2006 11:17 PM
