  #21
Old 11-26-2021, 06:40 AM
nhaudio nhaudio is offline
Default Re: Be Careful When Importing MP3s Into PT 2021.10
@Jeffro: I had an .mp3 import issue yesterday.
(https://duc.avid.com/showthread.php?t=417939) It only caused clicks and pops, not full scale noise or anything painful. I can send the offending .mp3 if it would help. Send me a message if you'd like it.
Cheers!
  #22
Old 11-28-2021, 08:12 AM
AudioNerdz772 AudioNerdz772 is offline
I’m getting clicks & pops on all imported mp3s. Running ultimate on Big Sur on m1 Mac mini. It’s nauseating & I’m going to spend hours re importing and re bouncing files for clients when it’s fixed.
  #23
Old 11-29-2021, 02:02 AM
innesireinar innesireinar is offline
Maybe it could be related to the dimension of the file. Yesterday I tried to import a 90 MB mp3 file and had this issue. Full scale distorted noise. Then tried to import some common song dimension files of about 3 MB and they worked fine.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
  #24
Old 11-29-2021, 02:09 AM
I found a workaround. Converting mp3s to wavs with an online file converter fixed the issue for me.
A mod said they are investigating but Im just gonna use wav until fixed.
  #25
Old 12-08-2021, 01:49 PM
Tweakhead Tweakhead is offline
I repeated my test for the new release today (v2021.12) with that same MP3 file. Exactly the same result. 5-10 second beachball during import, finally carries out the import, total waveform and audio corruption once imported.
Booted back to my Pro Tools 2021.6.0 partition. Works perfectly.
I guess nothing in the import engine got addressed this release.
I saw several other reports in different threads over the last month or so with similar import problems.
  #26
Old 12-08-2021, 01:50 PM
All you have to do is convert the mp3 to a wav and it fixes the problem.
  #27
Old 12-08-2021, 02:09 PM
Does anybody know if Avid have sample files where this fails? Where you able to get them one? This was a problem, then was not, then Avid seemed to contemplate their navel more, but then seems radio silence.
  #28
Old 12-08-2021, 03:38 PM
Sardi Sardi is offline
That’s not a fix, that’s a workaround.
Valid yes, but it appears something is broken and needs addressing.
  #29
Old 12-09-2021, 01:16 PM
glennaudio glennaudio is offline
Had an issue with an mp3 file imported into pro tools 3 different times (same file).
First import, it was crackling and popping like rice crispies but I could still hear the music.
Second import, it came in as absurdly loud white noise....no audible music.
Third import, same as second.
I used to Logic to import the mp3 (with no issues) and export as a wav. I understand this is only a workaround but it's obviously a bug if Logic can take the same exact file and import it clean.
Avid, please check into this issue as this is sometimes a crucial part of my daily workflow when working with student projects.
Pro Tools Carbon | HD Native 2021.12 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Mercury | Komplete 13 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock | S1 | MacPro 7,1: 16-core 96GB RAM W5700X GPU OS 11 1TB SSD +OWC 1m2 2TB SSD (samples) +Sonnet M.2 4x4 4x2TB Samsung Evo Plus SSDs in RAID 0 (sessions)
  #30
Old 12-09-2021, 08:36 PM
Yea tell me about it. I just paid avid $800 for update for m1 compatibility.
But I can’t wait around crying to avid. I would miss $500 a day.
importing downloaded .mp3s jpmorgan Pro Tools 12 13 11-23-2017 07:30 AM
Pro tools not importing MP3s emilicuadras Windows 1 08-10-2011 12:19 PM
Importing MP3s corrupts saving option mariang Pro Tools TDM Systems (Mac) 0 05-16-2007 03:52 PM
importing mp3s MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-20-2005 03:46 PM
Importing MP3s; files truncated davfries 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-04-2004 01:16 PM
