Old 09-30-2022, 06:57 AM
Christo_Bach33 Christo_Bach33 is offline
Default Playback Issues, Mac vs. Protools
When I turn on the computer, I can open, say, Spotify, and I can select my HD Native Thunderbolt as my playback speakers for my iMac, and I can hear through my system/monitors.
When I launch protools, my HD Native Thunderbolt disappears from the list of playback options for the iMac itself, HOWEVER, I do see it/can select it as the Protools playback engine, but obviously, because the computer can't select it itself, I get no playback/sound when working in protools.
If I close protools, it re-appears as an option for the playback for the iMac itself, and if I want, I can open spotify and play music like before, and hear it through the system.
I should also note, just to troubleshoot, I opened with garage band and everything works as it should I hear everything through garageband, no issues.
I've uninstalled and reinstalled everything. My HD Native Thunderbolt Firmware is current, my protools is current, my iOS is current and compatible. I've unplugged and replugged everything.
Old 09-30-2022, 07:33 AM
Default Re: Playback Issues, Mac vs. Protools
Working exactly as expected. Pro Tools (unlike GarageBand) is not accessing the interface via CoreAudio, and wants exclusive access to the interface. If you want to route other CoreAudio to/from Pro Tools sessions using DigiLink interfaces there are multiple ways of doing that, including physical digital IO like S/PDIF out the Mac into a DigiLink interface, or the new Aux IO feature in Pro Tools 2022.9.
Old 09-30-2022, 10:03 AM
https://youtu.be/ULkuwxJTGtY
Ah, weird, as I've never had this issue before, but sure enough, you are right! Thanks!
New laptop, issues launching protools - now issues with Ilok after re-install tsfisk Licensing & Accounts 6 07-30-2021 05:31 PM
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) Lucky Bastard Getting Started 6 01-16-2014 03:29 PM
ProTools 9.0.5, iLok issues, Digi 003R+ issues zachbot Pro Tools 9 6 10-12-2011 08:19 PM
Fuzzy Static with ProTools playback and window media files playback 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2011 05:41 PM
playback issues on protools m-powered alyssa ann Pro Tools M-Powered (Mac) 0 09-19-2007 05:09 PM
