Old 05-26-2022, 08:41 AM
quadraphonics quadraphonics is offline
Default Re: Cannot Bounce to Disk because of...
This is still happening here. We have trashed all preferences. Updated all of the plug ins. This even happens on sessions where there are no plug ins outside of the default Digi Plug ins.
We are running Pro Res video off of a StorNext shaere.
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 10-12-2022, 08:56 AM
We have gone through Pro Tools and updated everything.
This error still happens daily.
I am told that this is a Pro Tools issue, but I am wondering if it is an issue with compatibility between StorNext and Pro TOols.
Randall
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 10-12-2022, 06:20 PM
smurfyou smurfyou is offline
Are these bounces with video or just audio?
I've used all manner of local and network storage (but not StorNext specifically) and I can't recall having this error. Are you connected via Fibre or Ethernet? Not that it should matter just for the sake of detail.
Have you tried with video offline or even disconnecting from the share?
~Will
Old 10-12-2022, 06:24 PM
Also has Support asked for logs?
~Will
Old 10-13-2022, 05:15 AM
its2loud its2loud is offline
Randall
What happens when you move the video file to the local drive? If the bounce works then you just found your answer. Also, where are you saving the bounce?
Locally or externally? Have you tried bouncing to Same as Source codec?
Old 10-13-2022, 06:30 AM
We have tried bouncing locally and externally with the same result. We are always on Same as Source.
Randall
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 10-13-2022, 06:31 AM
Both, but usually video when it happens. We are connected with 10g fiber using an ATTO TB device(Thunderlink FC 2162).
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 10-13-2022, 07:07 AM
Randall
You’re on Windows? With PT 2020.12? And you’re saving the bounce to the local drive?
And you tried a bounce with a completely empty session containing just the video and guide track?
A long time ago, rewire was hanging up bounces.
HTML code is On
PT12 on Windows 7 Pro- no multiple bounce source tracks in Bounce To Disk window? js_nyc Pro Tools 12 6 04-21-2016 03:37 PM
Bounce to Disk: Bounce to disk length is longer than my track on my time dijitalhorse Pro Tools M-Powered (Mac) 1 02-23-2016 06:27 AM
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 12:41 PM
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade AllThingsMusicStudio macOS 0 06-28-2012 07:16 PM
could not complete the bounce to disk command because: a disk is full -34 help? Henrydm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-27-2010 09:07 AM
