#21
Re: 64 Bit Pro Tools? RTAS Working on ALL Cores?
From what I've seen, CoreAudio is always ready to go. When a new Mac computer or OS is released, AU applications like Logic are ready to go from day one. There's no tedious, enormously long waiting period to use new hardware. I'm sorry, but in my perfect world, I'd rather have the company writing my application to have a product that conforms to the OS and hardware. Otherwise, we're always waiting, and by the time everything is compatible, the computer is already on the way to being obsolete. That's really a deplorable situation, and one we shouldn't have to suffer. Quote:
At any rate, there's a lot changing right now, and a lot of new options popping up. It's both exciting and agonizing. It would be nice to know if Digidesign has anything groundbreaking on the way, but that's not possible. My fear, too, is that if they have a new, high-end system in the works that replaces HD Accel and changes a lot of the rules, they're probably not going to want to release it in a down economy. The initial market reaction to a significant new product is extremely crucial. If people held off buying (because of the economy, or for whatever other reason), it could be a major setback. Perception on how something is being adopted is extremely important. |
#22
I was wondering when you'd be getting around to that... |
#23
At some point, isn't it just good marketing sense? I mean, when it comes to their broader vision for the future? I really don't understand the deafening silence about this stuff from Daly City. Nearly every other major company will give you at least a broad-brush picture of their plans for the future. Car companies do it, electronics manufacturers of all kinds do it, Apple does it, Microsoft and Intel do it, NASA does it.... This is the kind of thing that helps to excite the base, inspire, and foster brand commitment. Wouldn't you agree? |
#24
The answer from M-Audio is IT CAN'T (I just talked to someone in support). The latency of the 2626 is based on the buffer settings of the software you are using it with and therefore it CAN NEVER achieve the same low latency inherent in a TDM system. It might be able to do a "low latency mode" similar to the 002/003 but even then the latency isn't as low as a TDM system. and while you are probably just reading the specs off the website... you cannot actual do 26 channels of In and out simultaneously with the 2626. If you keep reading the spec... "select from any of the 26 hardware inputs and 26 software returns as sources for its 18 input channels" You can only do 18 in and out simultaneously. It's selectable in banks of 8. You CANNOT have ALL 8 mic preamps PLUS all 16 ADAT PLUS SPDIF. It absolutely will not let you do that. |
#25
I find, the people that do the most bitching about software and are always jumping ship to the next "latest and greatest" DAW spend more time trying to learn the new software and hardware than they do creating music. And once they have the new software down and can finally start producing music in a reasonable amount of time, then someone else comes out with something better and so they abandon their new program for the next new program and the cycle continues. |
#26
#27
The 2626 has a DSP mixer on board that is separate from Pro Tools, and allows you to make cue mixes at HD latencies including 8 different aux sends. Yes, HD latencies: <2ms @44.1, <1ms @ 96KHz. This works completely perfectly for all your tracking needs which is when latency matters. Unless you are trying to track through plugins which I personally never do...I use real guitar amps and outboard. If you need that facility I would look at the Metric Halo line for a modern implementation. The 2626 also will allow all 26 channels to be recorded simultaneously. Yessindeedee. The only catch is that digidesign finds it an absolutely terrifying development and has decided to cripple Pro Tools (dis)M-powered to only support 18i/o. Digidesign also crippled it to have a minimum latency for RTAS plugins of 128 samples (but you can still use the DSP mixer to have HD latencies on foldback). Digidesign can remove the cripple code in a simple toggle...they might sell an upgrade toolkit or something that unlocks the full i/o capability, or it's possible we could get enough customers furious enough that digi just decripples it for free. It's natural that digidesign would find it so terrifying, as there is no computational challenge left in digital audio. A system with more power than an HD6 can be made today for a few hundred dollars. So to maintain their gouging gross margins they are trying to convince people like you that HD systems are still necessary for professional work, via crippleware policies on the native stuff. The only way they can get away with that is on the strength of their software which people have mentioned in this thread. But things like Reaper and Metric Halo and the like are being made by very, very smart people and digidesign will have to take a different tack to defend the franchise shortly. |
#28
It's not a down economy that they would be worried about. It is introducing the product without a must-have value proposition. The crippleware policy creates an artificial must-have for the HD line. By the time their new system appears, the OpenCL and other technologies you guys are talking about will be here, and competitors will be demonstrating 192 simultaneous i/o with <1ms latency DSP into a native system like Logic for a couple thousand dollars or so total cost of ownership. So how does digidesign put out a profitable line when all their real competitive advantages are already sold today for $250 in the MBox micro? Will enough people continue to tolerate the crippleware approach...to the tune of $10,000 and up? |
#29
http://icrontic.com/news/2004-avid_tech_to_buy_m-audio |
#30
But as part of the deal Avid let M-Audio retain its own management, R&D and sales staff down in San Diego. Avid got digidesign to make Pro Tools (dis)M-powered but digidesign views their step-sister as a competitor. The sales staffs say vicious things about the other company to the dealerships (very amusing to the dealers). The 2626 completely blows the 003 out of the water on every level conceivable. Basically M-Audio read everything people complained about the 003 and fixed it. The converters are way better, there is SMUX for all 18i/o at 96KHz into Pro Tools, there is HD-latency monitoring, including on external converters (low-latency monitoring does NOT work with external converters in PTLE), the preamp gain stages are completely bypassable, there are 8 preamps, it's a single rack space, it operates standalone as an ADAT AD/DA converter, and I'm probably forgetting half of the advantages. Oh yeah, it's about half the price. Make no mistake this was a direct assault on digidesign's hardware pre-eminence and digidesign responded. No Complete Extortion Toolkit for you! |
How many cores for RTAS in playback engine? | Logichead | Pro Tools TDM Systems (Mac) | 10 | 10-11-2011 06:25 AM |
MDW Hi-Res Parametric EQ 3.0 (TDM/RTAS)not working in pro tools 9.0.2 | odeu87 | Pro Tools TDM Systems (Mac) | 0 | 04-10-2011 06:34 AM |
You are running out of CPU with one RTAS on 8 cores?! | Montrealaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-31-2009 02:33 PM |
Pro Tools 7 & RTAS Instruments not working | wiggzaro | Pro Tools TDM Systems (Mac) | 24 | 05-21-2008 03:17 AM |
Can't leave RTAS set to all 8 Cores?? | alw4416 | Pro Tools TDM Systems (Mac) | 12 | 04-11-2008 12:10 PM |
