Old 04-02-2022, 01:10 AM
fork-media fork-media is offline
Default do people still punch in? destructive record crashes
I am going down a list of fixes - punching into the mix and stems - I've done around 200 points today I can totally replicate this crash
if I try to redo *the exact same* destructive record. ( ie insertion point and out point not moving it will crash - it even locks up the crash reporter..
just face palmed myself for forgetting again! ofcourse I am saving every 2 mins..
Any one else have this issue?
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 04-02-2022, 08:40 AM
Default Re: do people still punch in? destructive record crashes
With drive space so affordable, must you use destructive record? Could it be related to your ancient interface? Or the adapters to get FW400 connected?
Old 04-02-2022, 03:13 PM
just a workflow I am comfortable in.
record out Mix 5.1 + D M E M+E also doing Stereo folds at the same time.
10 lots of stems - thats a lot bouncing
and I dont usually have 200 points - when QC'ing sometimes just one or 2. so punching in is quick and you know its done as the rest of the file has been QC'd
interface is fine for days at a time = just destructive record if I punch the same same point twice?
come on bud its a software issue - I had this on PT11 as well in High Sierra
Old 04-02-2022, 03:47 PM
If lots of folks were seeing problems with destructive record, and I suspect enough folks do use it, I think you would be seeing screams here.
Is this only in 5.1? Or you can make it happen in stereo? In a simple session? Or only one/few large sessions?
Have you tried all the standard troubleshooting steps? Trashed prefs, removed plugins files? Tried starting from an empty session, If it looks like any chance it might be the session, try a Save Copy In. Tried as a new admin user? etc. etc. ? Even if it you really strongly believe is a standard Pro Tools software bug, just play the game and do the standard stuff, it should not take much time and should speed up you getting attention from support or other users here.
Have you filed a case with Avid support? Got a case number? Share it here if you want to try to get more attention on it. If you have a reproducible crash share it with Avid support.
What do the Pro Tools logs show? Long shot, and cryptic, but compare a crash to a good session use. ~/Library/logs/Avid/Pro*
Old 04-02-2022, 05:11 PM
reichman's Avatar
reichman reichman is offline
fork: FWIW, I've never seen this and I spend a lot of time in Destructive Punch mode. I'm quite sure I've made the same punch in and out multiple times with the current PT on Mojave. If I had to guess, you need to trash your Workspace Database files. That has cleared up weird disk stuff for me before.
albee: disks are inexpensive, but on a film mix with a zillion stems of different widths, doing regular punch and then consolidating takes a long time. We almost never go back to earlier versions of the stems, so destructive punch is a great workflow. And even more so when hitting QC notes. Fast and accurate.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 04-02-2022, 05:20 PM
just wondered as quite a few may be making the move up.
No entry in the logs - the crash reporter also freezes..
I see your trouble shooting tips thanks, trashed prefs, changed drives etc - it potentially could have a project based as I was having this on the old
machine too ( PT11 and High sierra )
trcking it down will take time - I think I will just keep on remembering to save often and keep the 'insertion follws playback on' until the delivery. might have a go next week when nothing on
if anyone else runs into this I'd be interested..
Old 04-02-2022, 07:34 PM
albee: disks are inexpensive, but on a film mix with a zillion stems of different widths, doing regular punch and then consolidating takes a long time. We almost never go back to earlier versions of the stems, so destructive punch is a great workflow. And even more so when hitting QC notes. Fast and acccurate.
thanks Reichman - will give that a go. cheers
Old 04-02-2022, 08:49 PM
its2loud its2loud is offline
This sounds like a disk access speed issue. Consider using pre/post roll with destructive record. Maybe 1sec minimum. Also, try increasing your disk cache if you can afford the RAM. I prefer to be safe when destructive recording and allow Pro Tools to buffer some data prior to actually punching in.
Old 04-02-2022, 09:55 PM
audiolex1 audiolex1 is offline
Are your playback and record drives the same? When working on the same system for PB and Destructive record, I've always had a separate record drive.
Never had issues when it was like that.
Old 04-02-2022, 10:50 PM
ok will try upping the buffer thanks
playback drive is seperate to the project drive..
its SSD as well
have trashed the prefs with the PT prefs app. and also used the go function outlined above..
I will no doubt forget again - its just so easy to leave it in record monitor and just punch in the notes.... mostly a monster thats either too loud or too quiet..
HTML code is On
Destructive Record punch-ins slightly out of sync. antonis Post - Surround - Video 8 02-22-2019 09:52 PM
Destructive Punch crashes PT paulo m Pro Tools HDX & HD Native Systems (Mac) 4 03-20-2017 10:44 AM
Destructive Punch Record-Custom lenght of track? Eric L Post - Surround - Video 8 08-18-2007 10:42 AM
Pops on punch out of destructive record CD Productions Post - Surround - Video 17 01-29-2007 07:08 AM
Destructive Record ('Click' sound when using punch Flingus2001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-12-2005 05:38 PM
