Can only certain automation points be selected together?
Scenario: you place points in your automation line, let's say some are toward the top of the lane, others are at the bottom, e.g. left, right panning, or high volume, low volume. In other DAWs you can marquee select just the bottom points to move them. or just a couple points, or just the top points, etc.
I can't see how to choose only the points I want in PT. If I do a select, it sweeps across the entire lane and I can't pick or differentiate between the top points and the bottom points, since the selection is entirely vertical which includes the entire lane top to bottom. I figure there must be some trick or tool that I'm unaware of because it's a common way of selecting. Thanks! |
Re: Can only certain automation points be selected together?
I don't think so. PT has inherited its automation-point design from the early 90s. It would probably require a very deep rewrite of the software to get past that limitation. You're right that it's quite behind some other DAWs in this respect. It's one of the things I miss most from Reaper.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Tiny fixes or edits to those automation dots is painful for me almost every time...
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
How to marquee only certain automation points | macmuse | Avid Pro Mixing General Discussion | 0 | 10-05-2021 06:52 AM |
automation points | fmilian | Pro Tools HDX & HD Native Systems (Mac) | 3 | 10-28-2014 08:54 PM |
How to 'group' automation points? | nilsk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-06-2008 12:36 PM |
Automation points resolution | ishur | Pro Tools TDM Systems (Mac) | 3 | 09-17-2006 02:30 PM |
Keep losing automation points | DEXTERITY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-18-2005 05:05 PM |
