CPU usage jumps up while doing nothing!!
OK, is this a 6.1.1 'feature'?
After upgrading to 6.1.1 everything was working fine. I had a marathon session where I had a band in my studio and recorded 7 songs. No problem. The next day we start mixing down the tunes. I find that in the beginning of a mixing session I can add a TON of effects and everything is fine - my CPU usage meter is about 25%. While the song is playing (with a variety of automation), the meter is solid and remains at about 25%. Once I stop playing, the CPU usage meter jumps up every second about 10% until it reaches about 90% (yellow zone) and sometimes it even peaks into the red. If I clear the red by clicking on it and then start to play the song again, it will drop back down to about 25%. My problem is that sometimes, even though I have run a song 4 or 5 times (with CPU usage around 25%), I will make one small change to an EQ or some other effect and suddenly the CPU usage peaks out and I cannot continue without removing some effects. At this point, I usually just save what I got and reboot. If I do that, it falls back into place. Could 6.1.1 have a memory leak (or more correctly...a CPU leak)? BTW - This never happened with 5.3 or 6.1 Andrew |
Re: CPU usage jumps up while doing nothing!!
Are you using a Pentium 4? Are you using D-verb? This might be the denormalization bug. Search the DUC for denormalization, there's a workaround you might try.
Quad 2.5 G5, 4.5G RAM |
Excellent! It would have been a while before I figured that one out. Thanks for the help!!
Wow, this issue has been around for over a year and they haven't fixed it yet? Amazing... |
Did you verify that denormalization was the problem?
The same thing happened to me when I was mixing a song with D-Verb on 3 channels. I use PT 5.3.1 on P4 2.66 Ghz. I removed it from a one channel and everyting was fine.
HDN jumps to high CPU usage | propower | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-30-2013 10:00 PM |
Session freezes and CPU usage jumps to 95% | highrisenola | Pro Tools M-Powered (Win) | 8 | 01-19-2012 03:31 PM |
CPU usage jumps, -9128 errors start | red tape | Windows | 5 | 11-27-2011 09:08 AM |
CPU usage jumps to 100% when saving if edit window minimized | frantik | Pro Tools M-Powered (Win) | 20 | 10-25-2009 05:22 PM |
System usage meter jumps | kaotikmuzik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2004 08:26 PM |
