Old 01-23-2011, 09:55 AM
Strider Strider is offline
Default Have you gotten this error when opening a session?
I just upgraded a couple weeks ago to PT v9.0.1
This system is a 003rack, Euphonix MC Transport and MC Mix, Mac Pro 2 x 2.66 quad core, plenty of memory, etc.
Issue #1)
I'm getting this error message about 25% of the time when opening the Pro Tools application; it's not while opening PT from a session file in finder, just the app from the dock. It says:
Could not complete your request because Pro Tools could not set sample rate to specified value..
My hardware is on, so I assume it can see it or it would say, "cannot find PT hardware."
9 times out of 9, when I try to launch again, it launches no problem.
Issue #2)
BTW, I cannot get this system to open a session file from the finder level. It appears to launch for the first half-second, but then does nothing.
Anyone else dealing with these bugs?
Thanks, Mark
Mark Keefer, M.P.S.E.
http://miscellaneouscreativity.blogspot.com/
Old 01-23-2011, 12:54 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Have you gotten this error when opening a session?
What troubleshooting have you already done?
OS version?
What sampling rate is set?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-23-2011, 01:42 PM
Troubleshooting - none. I have no idea where to start for this.
OS 10.6.6
48k, 24bit
Thanks.
Old 01-23-2011, 01:50 PM
Try:
http://duc.avid.com/showthread.php?t=54888
http://duc.avid.com/showthread.php?t=287927
http://avid.custkb.com/avid/app/self...p?DocId=349427
http://duc.avid.com/showthread.php?t=202940
Park
Old 01-24-2011, 01:20 PM
Thanks Park for all those helpful links. As I'm swamped at the moment, I can't take the time necessary to go through the vast pages of info.
I was just hoping to get a quick answer from someone if they've seen this. And btw, there's no error number when it comes up. Just text.
Thanks,
Mark
[IMG] code is Off
Error Opening Session adam79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-10-2012 12:35 PM
Error Opening Old PT Session Imgoinmad Pro Tools 10 3 10-30-2012 08:31 AM
Opening Session Error Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-24-2007 11:50 AM
DAE error 51 opening session canoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-26-2006 06:00 PM
Error opening session w/6.1 Pirate Post Pro Tools TDM Systems (Mac) 12 02-13-2004 12:12 PM
