My System Took a Dump! Thoughts?
Hi all,
I'm running a Mix3 system, OS 10.3.9, PT 6.4.1cs4, on a dual 1Ghz processor G4 with 1.5 gig of ram. Tonight I was working through a mix session when, with the system at idle (no playback, editing, processing, anything), both of my displays went to a solid pattern of tiny grey squares and the entire system froze--C24 went offline, the displays remained frozen, and no key commands had any effect. I had to turn off the system by holding the power button to shut it down. I unplugged the CPU and let it sit for a few minutes, but when I tried turning it on again, the CPU powered up and made the apple sound, but the displays never woke up. At first I thought it could be a video card issue, but I didn't think a vid card failure could lock a whole system up and freeze it, etc... I opened the CPU case and turned the system on--my core and farm cards have a yellow LED lit at the end of the card closest to the back of the case. Not sure if that's a good thing, but everything seems to be seated properly and dust-free. Anyone have any ideas or experience in a situation like this? Any advice would be greatly appreciated. Thanks J Update: I removed the vid card and switched it out with another I had on hand. Problem solved. Guess a bad vid card CAN make a whole system geek out. |
Re: My System Took a Dump! Thoughts?
A tip on video cards: Using the old 32meg Nvidia AGP cards (which can drive 2 big monitors) or one similar to it, will yield best performance on these MIX systems, as the PCI bandwidth will be much less than a newer fast AGP video card. I made this mistake a few years back when I put a nice 256 meg ATI AGP in there, and the PCI meter (in combination with my chassis) went through the roof. YMMV, Best Walt
It's only R'n'R but I like it. |
Can I dump unneeded Digi System Pref Panes? | Mike Harrison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-01-2013 08:48 PM |
Need a System - thoughts? | IntelDoc | Pro Tools TDM Systems (Win) | 33 | 04-16-2010 08:48 PM |
New Pro Tools Windows System Thoughts | MorganPost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-01-2005 12:53 PM |
Any System Fans....thoughts on "Mezmerize"??? | Third Eye Studios | General Discussion | 0 | 05-18-2005 11:10 PM |
System thoughts... | mrockas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-31-2001 10:56 PM |
