002 Hardware Inserts
Question: when you use a hardware device as a plugin, a) does the signal go through an extra D/A and A/D step, or b) does the 002 have an internal patch matrix?
I'm pretty sure the answer is 'a', I'm just verifying.
Quad 2.5 G5, 4.5G RAM |
Re: 002 Hardware Inserts
I use an external reverb and take the analog outs so the signal goes to a D/A then into the reverb unit where it is converted to digital again. Then D/A on out and then A/D back in Pro Tools.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
Hardware Inserts | trackone | Pro Tools TDM Systems (Mac) | 6 | 01-27-2012 06:22 AM |
Hardware Inserts on PT 9 | Obe1 | Windows | 0 | 06-09-2011 08:19 AM |
Hardware Inserts in LE??? | plex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-26-2007 11:56 AM |
Hardware Inserts | CosmicJunkie | Pro Tools TDM Systems (Mac) | 1 | 11-20-2007 03:12 AM |
