Old 01-28-2003, 07:07 PM
SpillingSounds SpillingSounds is offline
Default Digi 001 & IRQ sharing
I was just checking out my system information and saw that my Digi 001 card and my USB controller are sharing the same IRQ. I think this bad, does anyone know if this can slow down the Digi and how I can change it if it needs to be?
Pro Tools M-Powered 7.3.1cs2, Delta 66 w/Omni I/O
Custom AMD64 3000+, 1GB Ram, 40Gb System, 80Gb Sample Drive, 80Gb Audio Drive.
Old 01-28-2003, 07:25 PM
Allen Hallada Allen Hallada is offline
Default Re: Digi 001 & IRQ sharing
Which OS are you using? Win XP, WinME or Win98SE?
Which motherboard are you using?
Which slot do you have digi card in?
Allen [img]images/icons/wink.gif[/img]
Old 01-29-2003, 05:50 AM
I'm using Windows 98SE (I'm switching to XP in a few months). I have the Digi in the bottom most PCI slot in my board. This is the only card installed.
Dell 8200 Series
Pentium 4, 1.7Ghz
512GB RDRAM
60Gb Hardrive
Old 01-29-2003, 09:06 AM
I doubt that your bios in that Dell is going to allow you to hard force the IRQ so you are best off switching the 001 card to slot 3 and check again. That is the third slot from the AGP video slot not counting the AGP slot. If that doesn't work try another until you find one that gives 001 its own IRQ.
Good luck,
Old 01-30-2003, 02:36 PM
I changed to Slot 3, and it was still sharing the same IRQ. I went into BIOS and was able to switch the Digi card to it's own IRQ. Hopefully this will help. Thanks for the advice.
Sharing Digi 003R with 2 different systems Ty Ford macOS 0 11-23-2011 06:07 PM
Just sharing the digi love macr0w 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-18-2005 07:45 PM
Sharing the Digi 001 with a PC Johnbearorl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-15-2002 01:20 AM
digi sharing Irq with promise controller ALAN MCKNIGHT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 01-13-2002 12:02 AM
Digi sharing IRQ With video Card Olly J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-06-2002 05:54 PM
