No plug-in automation settings available
I had this thing randomly happening a few times, initially with Oxford plugs but I've now noticed the same thing with others as well.
Sometimes, when I have more than one plug-in on an audio track, if I try to automate one of the lower ones in the chain, no automation settings are available in the window - in fact, I'm presented with a blank window and a choice of plugins for which I want to see the automation parameters, and if I toggle to the earlier ones, the parameters are all there. This could happen when I have 2, 3 or more plugs on the same track, and the beheaviour isn't repeatable, sometimes it happens and some other times it's no problem at all. I'm running PT 6.9.3 on a dual 2.7GHz G5 with Mac OS 10.4.3, HD3 Accel |
Re: No plug-in automation settings available
Hi Marco
You should update your ProTools software to v6.9.3cs4 which was released about a month ago and addresses exactly this issue. I had similar problems to you but since I downloaded this update, I've had no problems
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 01:04 PM |
Saving Plug In Settings and Automation | snark | macOS | 3 | 08-10-2011 10:14 PM |
Automation of Plug-in Settings | dsetaro | Tips & Tricks | 2 | 12-24-2007 07:35 AM |
Can you retreive saved plug in settings via automation? | Rob S | Pro Tools TDM Systems (Mac) | 3 | 11-23-2007 06:36 AM |
Automation on SAVED plug in settings | jkatcher | Post - Surround - Video | 2 | 06-26-2006 01:42 AM |
