Old 05-14-2023, 06:00 AM
bonzerboy bonzerboy is offline
Default IK Lussen Master Console
I have been playing around with this and has a nice touch. If I put a meter after it looks as it goes over.Does anyone use this plugin or stand alone? Would it be best to pull level down for final bounce or would putting another limiter after be better ?
Wow am I groovy or what
Old 05-15-2023, 02:30 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: IK Lussen Master Console
Great plugin. Great sound and preset groups.
You can get under the hood and tweak the threshold for the units in the chain etc. but more options would be probably nice. That said, I like its limitations!
Regarding going over, I don't think I have ever seen this condition. Where is your Master Fader set? Is it above 0? Do you have gain being added after the Lurssen plugin? If so, make it the last plugin in your chain (before metering).
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 05-20-2023, 05:51 AM
It seems if I put a meter after the console it goes into the red
Old 05-20-2023, 08:50 AM
Which meter plugin? Any gain option in this plugin?
Stephen
Old 05-23-2023, 03:53 AM
I put mastering the mix levels,, it his over on the true peak,, I put the IK meter on looks like it is staying below. I wonder if I should but the waves l1 or l2 just tame any overs?
Old 05-24-2023, 02:55 AM
I don't have any plugins from masteringthemix.
Try some other alternative or just the dBFS reported on the Master in Pro Tools. Lurssen is pretty stellar IMHO 🤩
Stephen
Old 05-24-2023, 03:55 AM
danyg danyg is offline
Is the plugin True Peak? If not, there might be overloads.
You better set the output to -0.2 or use a Farbfilter L2 in True Peak mode afterwords. f.Ex Waves L2 is not True Peak either.
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 05-25-2023, 04:36 AM
simon.a.billington simon.a.billington is offline
Stephen
I haven't really had much of a play with it. Usually in situations like this you can insert an eq prior to the mastering plugin to tailor how the audio hits to get the most out of it.
HTML code is On
Alesis Master Console.... masonicweird Pro Tools 9 0 03-01-2011 01:55 AM
003 console + tranzport = Losing master fader function? GloryIsSilent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-30-2009 08:04 AM
Fixing Clipping in Master in Master Fader pakobo7 Pro Tools M-Powered (Win) 10 09-16-2006 10:53 AM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
Master Fade & Master Plug Ins Kenny Gioia Tips & Tricks 10 04-17-2001 02:39 PM
