Hard Drive FW800 Dock
Hi
I just wondered if anyone uses a hard drive dock with firewire 800. I've looked around but none of the online sites actually say which FW chipset is used. I know that PT is only qualified using Oxford 911, 912 and 924 chipsets. Does anyone use one of these that works? If it matters I'm on an iMac 27" 3.4GHz i7, 12GB RAM using Snow Leopard Cheers Paul |
Re: Hard Drive FW800 Dock
Check out OWC. They state which chipsets they use and it is the Oxford.
http://eshop.macsales.com/shop/firewire/
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
not on the Drive Docks
http://eshop.macsales.com/shop/Newer...ard_Drive_Dock or am I blind? Ask OWC they are good about these kind of things
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thanks for the info. The only dock I can find that has a chance is one with an Oxford 944se chipset. This isn't on the supported list but it is the same chipset as used by one of their 'for best performance' hard drives. I find it a little ironic that one of the recommended HDDs actually has an unsupported chipset.
I think I'll shelve the dock idea and just use my current USB dock for backup purposes. Now...to find a FW HDD with a supported chipset over here in the UK? |
"Bridge Chipset Oxford 944SE UPDATED" Other World Computing (OWC) has added the newest Oxford chipset to its Mercury Elite Pro Mini Quad Interface models. The new Oxford 944SE chipset offers faster data throughput, up to 300MB per second, with reduced power consumption and cooler operation. Read more: http://www.macnn.com/articles/11/06/...#ixzz1UpnnyWLf
Hi
I just thought I'd update. I bought (with an 'if it doesn't work, bring it back' deal) a G Drive Mini 500GB FW800/400 . It has an Oxford 934, which Avid only qualifies with FW400. I've been using it for a few days with the FW800 port running on bus power only and it has been rock solid on some pretty big sessions. Happy! |
Glad it's working out for you... Not sure which interface you are using (FW, USB...) the thing that makes FW800/400 an issue is only if you are putting a FW400 interface on the same port. What the iMac should do is step down to FW400, because the interface would force it to do so. People sometimes have issues with that type of configuration and that's why Avid states it only qualifies FW400 drives and only with Oxford xxx bridging chips. If that makes any sense at all. I run 2 FW800 drives and a FW400 interface off one single port with no problems, but it is only transferring data at FW400 speed.
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
I've plugged it straight into my shiny new iMac's FW port. The G Drive only has FW800 sockets but it comes with a lead that converts 800 down to 400. I haven't used this lead but I'm pretty sure it is transferring at very high speeds. This is my first FW device so I can't be certain as I have nothing to compare it to.
Avid doesn't advise against all FW800s. With the Oxford 911 (and a couple of others), both 400 and 800 are supported. With the 934, only the 400 version is qualified but I assume mine is using 800 (so far without issue, touch wood!) Paul |
Hard Drive Dock with iMac | paulrgmusic | macOS | 5 | 08-13-2011 04:18 AM |
dae error with external fw800 hard drive and pt8 on mac | DejanT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-08-2010 04:47 AM |
FW800 port —> FW800 Drive —> Out FW400 port on Drive —> Pro Tools LE FireWire | maharzan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-03-2009 08:37 AM |
Noise w/G4 PowerBook + FW800 Hard Drive | ArtGarceau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-30-2006 11:31 AM |
DYI FW drive dock... | where02190 | General Discussion | 0 | 10-04-2002 02:30 PM |
