Old 06-14-2007, 06:07 AM
mickdoo22 mickdoo22 is offline
Default 10.4.9 COMBO Update Questions.......
I am currently running a Mac Pro with OS x 10.4.9, and PR 7.1.1. I know DIGI is recommending downloading the 10.4.9 COMBO Update and 7.3. However....I downloaded the 10.4.9 COMBO update, and tried to install it, but I get an error message: "You cannot install Mac OS X combined (Intel) on this volume. This volume does not meet the requirements for this update".
I see so many other folks here have installed it with no problem. What's the secret?
Old 06-14-2007, 06:10 AM
soundproof soundproof is offline
Default Re: 10.4.9 COMBI Update Questions.......
Mac Pro G5 .../snip/... error message: "You cannot install Mac OS X combined (Intel) on this volume. This volume does not meet the requirements for this update".
You've downloaded the Intel version of the combo update - download and install the PPC (as in PowerPC as in G5) version.
Edit: Oh wait a minute-which is it, your computer? The Mac Pro (Intel) OR the G5 (PowerPC)??
Old 06-14-2007, 06:57 AM
I have a Mac Pro.....(sorry for the confusion)......I did download the Intel version, but I keep getting the error message.
Old 06-14-2007, 07:43 AM
Mark Reis Mark Reis is offline
Follow the links in the Digi Announcements section regarding 10.4.9 and you'll find a way to install 10.4.9 over the existing installation, which should eliminate any "software update install" related problems.
Mark Reis
Sound Designer
Old 06-14-2007, 08:40 AM
Default Re: 10.4.9 COMBO Update Questions.......
Thanks Mark......I actually scoured that, unless I am missing something. I downloaded the COMBO update, and it wouldn't install, so I tried the prebinding script as suggested, to no avail.
Old 06-14-2007, 09:49 AM
Park Seward's Avatar
Park Seward Park Seward is offline
10.4.9 has only been approved for 7.3, not 7.1.
However, take a look at the troubleshooting guide at the top of the DUC and follow those directions. Good luck.
Are you using the correct Combo?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-14-2007, 10:42 AM
That's why I am trying to install the COMBO update, because I want to install the 7.3 update.
I am sure I am using the correct COMBO....even the error message says so... "You cannot install Mac OS X combined (Intel) on this volume. This volume does not meet the requirements for this update".
I have gone through the troubleshooting guide about 10 times. Still nowhere.
Old 06-14-2007, 10:50 AM
DigiTechSupt's Avatar
Are you having any problems launching Pro Tools?
If not, there's no need to install the Combo update....
Avid Audio Tech Support
Support FAQ
Old 06-14-2007, 11:18 AM
I am not having any problem launching Pro Tools.....HOWEVER.....I am currently running 7.1.1 with 10.4.9. DIGI has only qualified 7.3 on 10.4.9. According to the website, I must install the COMBO update BEFORE I install 7.3 There lies the rub.
Old 06-14-2007, 11:51 AM
sky88dd sky88dd is offline
Try installing 7.3 then update it to the latest version which is 7.3.1 cs3.
If you don't have any problem launching PT, then its fine.
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Mac OS X v10.6.6 Update Combo (new jan.6) onepercentfree macOS 14 01-12-2011 02:50 PM
Mac OS X v10.6.3 v1.1 Update (Combo)? gthm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2010 12:19 PM
How bad is it to not use Combo update? Dizzi45Z Pro Tools TDM Systems (Mac) 11 02-11-2010 10:25 PM
Mac OSX 10.5.8 combo update Growlyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-16-2010 04:11 PM
10.5.5 combo update... ebonyles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 01-12-2009 09:23 AM
