Recording at low buffer settings. not possible.
I´ve been trying to record on pro tools 7.3.1cs2 (also 7.1) at buffer settings of 64 and 128 but that is not possible (error messages vary, problem with audio clock and various error numbers), my system won´t record unless the buffer is set to at least 512. Which of course is to much latency for accurate recordings. Can anyone look at my SiSandra and see if they can spot any problems? I can do this on my laptop which is a much smaller machine, kinda sucks
I´ve already downloaded the dual core hotfix and followed every single step in the XP problems thread. The network card only shows up in this report because I had to go online for the SiSandra software and forgot to turn it off before running the test. This is a Dell XPS 700 machine. SiSoftware Sandra System Host Name : RISINN User : Pro-toolarinn Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz Speed : 2.13GHz Performance Rating : PR7236 (estimated) Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache : 1x 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 threads sharing Mainboard Bus(es) : ISA X-Bus PCI PCIe USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : No System BIOS : AT/AT COMPATIBLE Mainboard : Dell Inc. 0YF432 Total Memory : 2GB Chipset 1 Model : Nvidia Corp nForce4 Intel Edition CPU to PCI Bridge Front Side Bus Speed : 4x 266MHz (1064MHz data rate) Memory Bus Speed : 4x 266MHz (1064MHz data rate) Video System Desktop Monitors/Panels : 2 Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 7950 GX2 Adapter : NVIDIA GeForce 7950 GX2 Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : WDC WD2500JS-75NCB3 (233GB) Hard Disk : WDC WD2500JS-75NCB3 (233GB) Hard Disk : LaCie Group SA LaCie Hard Drive FireWire+ IEEE 1394 SBP2 Device Hard Disk : LaCie Group SA LaCie 1394 Disk drive LUN 0 IEEE 1394 SBP2 Device Hard Disk : Apple iPod USB Device Hard Disk : TEAC USB HS-CF Card USB Device Hard Disk : TEAC USB HS-MS Card USB Device Hard Disk : TEAC USB HS-SD Card USB Device Hard Disk : TEAC USB HS-xD/SM USB Device CD-ROM/DVD : TSSTcorp DVD+-RW TS-H553A (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) Logical Storage Devices PTLocal (C:) : 49GB (13GB, 28% Free Space) (NTFS) Hard Disk (J:) : 49GB (15GB, 31% Free Space) (NTFS) Audio 2 (K:) : 135GB (116GB, 86% Free Space) (NTFS) Audio 1 (D:) : 233GB (175GB, 75% Free Space) (NTFS) Kiddi FW 1 (N:) : 114GB (62GB, 54% Free Space) (NTFS) Kiddi FW 2 (L:) : 149GB (24GB, 16% Free Space) (NTFS) CD-ROM/DVD (I:) : N/A 3.5" 1.44MB (A:) : N/A Removable Drive (M:) : 56GB (1.7GB, 3% Free Space) (FAT32) Removable Drive (E:) : N/A Removable Drive (F:) : N/A Removable Drive (G:) : N/A Removable Drive (H:) : N/A Peripherals USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Mass Storage Device USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : HID Keyboard Device Mouse : HID-compliant mouse Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Adapter : Broadcom NetXtreme 57xx Gigabit Controller Performance Tips Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
"Ok I promise, this is the last plugin I´ll buy!" www.syrland.is www.sturluson-music.com |
Re: Recording at low buffer settings. not possible.
I used to be able to record at low buffer settings until I upgrade from 6.9 to 7.3.....now only at 512 as the lowest.
Interesting huh? |
UPDATE!
I hooked up an mbox 2 (usb) and then I was able to record 32 channels at 44.1 24 bits for 2 minutes before stopping myself at 128 H/W buffer, no problems. Is my firewire card an issue here or what?
This is the research I have found from the DUC, google etc.
-Try a new firewire cable (trying this tonight) -Make sure DMA is enabled on all hard drives (which it is of course) -Possible 002 issue with firewire connectors (already have replaced power harness etc.). My setup has been running great for 2+ years and this happened once upgrading from 6.9 to 7.3.1. I cannot record lower then 512 on the buffer setting. Does'nt matter if I have 1 track or 20 record enabled. Any ideas other then reformatting? Digi?? |
What are the error numbers in the messages you're getting?
I tried removing all firewire devices from the bus, leaving Digi002 as the only firewire device on the system. At 128 samples I first get "problem detected with audio clock" then error - 6088 At 256 samples I first get "problem detected with audio clock" then error - 6088 I also tried various settings with the CPU usage limit, number of processors and the playback buffer and got quite a few visits from Mr. Bluescreen. Note, my system works very well with the mBox 2.
Hey Mark! Nice site and seems to be a cool studio you have.
A few questions, Which computer model do you have? how many firewire buses do you have, My system (Dell XPS 700) has 2 firewire buses. I´m just wondering if the 2 buses are conflicting or something. Any thoughts Digi??
I have a older AMD64 3400 that i built. 2 firewire (one in front, one in back). Solved the issue by reformating, and starting from scratch. It has been 2+ years so it was time anyways. All good now. Can record all tracks at 64 now. There is a point where you can spend too much time troubleshooting. Do you have the time to start from scratch? May be worth the trouble. |
Thing is, I just set this system up a few weeks ago. I have a XP MCE setup on another partition, I´m going to try and reformat all system drives and setup the system again and hopefully it will work.
Anyway I´m glad to hear that you have sorted your troubles out
Buffer settings for Mbox3? | Aussie169 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-09-2012 09:29 PM |
Buffer, CPU,DAE settings? | sil | Tips & Tricks | 2 | 02-11-2006 04:36 AM |
Buffer and other settings. | kitana_one | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-15-2005 09:14 PM |
Buffer Settings - HELP!! | Da Gatekeepa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-05-2003 08:53 PM |
Buffer settings | Forrest77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-29-2001 06:50 AM |
