Converting RTAS to Audiosuite...HELP!!
I am attempting to transfer my RTAS plug in settings to the corresponding audiosuite plug ins to improve the G5's efficiency. An error message pops up while im trying to import the RTAS settings into audiosuite that says a settings folder already has the same name. No matter what file name i assign to the settings folder, the message still returns. I am not being allowed to bounce heavily effected sessions to disk because the cpu is being overloaded and the bounce handler cannot keep up. Rather than trying to save the RTAS settings and import them into audiosuite, i also individually assigned the audiosuite plug ins the exact same settings that the RTAS plug ins had and the sound is drastically different. I made sure to process the audiosuite effects in descending order just as they appeared as RTAs and the conversion was still unsuccessful. I know that the RTAS and audiosuite plug ins are interchangeable and i need to succesfully complete these adjustments in order to complete my current project. PLEASE HELP!!!
Re: Converting RTAS to Audiosuite...HELP!!
Open the RTAS version.. and copy the settings into the clipboard and paste them into the AS version. (Command+SHIFT+C/V).
Not sure what's wrong with your system.. but you shouldn't have any problems saving and opening settings between RTAS and AS versions. Rail
what is (Command+[bleep]+C/V)?
when i open the RTAS version and pull up the settings menu, i save settings...then i removed the RTAs effect but selecting no insert...then i go to audiosuite and open the same plug in and select copy settings...then i process the effects and then the error message comes up saying the file name is already used in the folder...i have even name the plug in settins "oegjvoerjofaej" for instance and this error message still appears...do i need to adjust any of the buttons in the audiosuite effects or something?...this is so frustrating becuz everyone says that this process is simple and its not allowing us to complete it
Rail
You're getting an error message when you hit PROCESS or when you SAVE A PRESET?
Which one? Rail
i never save a preset...i go to the pull down arrows and save settings to whatever effect plug in (compresser,t-racks,etc.)
What you're describing sounds to me like saving a preset. Is the issue occuring then or when you hit the PROCESS button?
Rail
no im not saving a preset...i want to save the settings that i made to the RTAS and transport the effect's adjustments to Audiosuite
Preset... setting... the same thing.. different name. You haven't answered my question. Once you save a setting in a plug-in it becomes a preset.
Rail
Sessions not converting from TDM to RTAS | mrbobb | Pro Tools HDX & HD Native Systems (Mac) | 1 | 02-14-2012 07:02 AM |
possible converting rtas settings to VST? | musicmixer04 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-28-2011 07:52 PM |
Converting RTAS to TDM | lode | Post - Surround - Video | 2 | 07-30-2009 06:29 AM |
Converting TDM plug-ins to RTAS | schmargle | Pro Tools TDM Systems (Mac) | 3 | 01-15-2007 04:46 PM |
D-FX RTAS or Audiosuite ? | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-26-2002 12:48 AM |
