Crash After System Sits Idle
Although my system typically runs fine since installing XP, I have gotten the following message twice when my system has been sitting idle (usually after 30 minutes or more).
PFN_LIST_CORRUPT BCCode:4E BCP1:0000007 BCP2:0000037 BCP3:000001 BCP4:0000000 OSVer:5_1_2600 SP:1_0 PRODUCT:768_1 I have a dual boot setup, and have done all the performance tweaks listed on this board. Also, I have no other background apps installed/running (i.e. screen/power savers, anti virus, etc). Here is my system: PT Version: 5.1 w/Win98 & 5.3 w/Win XP (on seperate partitions of one drive) MOBO: MSI K7T266 Pro (MS-6380) CPU: AMD Athlon XP 1700+ Ram: 256M Drives (x2): 40G 7200 IDE (1 for apps; 1 for data) Like I said, both versions of PTLE usually run fine (as does Acid 4.0). Any ideas on what I need to do here are appreciated. Thanks. |
Re: Crash After System Sits Idle
I have similar problem with "Allen"Machine, except I get PCI_IRQ_NOT_LESS_THAN_OR_EQUAL_TO message. Same situation,too - sitting idle for a few hours....
In researching this, I found this website (might help you out Matt):
http://www.aumha.org/kbestop.php Looks like time to start the troubleshooting, but if anyone has suggestions, please let me know. Thanks. |
I've been struggling with crashes for a while now, but found my issue finally yesterday. I have an Asus P4PE motherboard (845PE chipset). I had installed the Intel Application Accelerator driver that came with the M/B. Turns out that IDE driver completely screwed things up for me. I uninstalled it and used the latest chipset s/w from Intel.
Check out Asus support and Intel chipset S/W for more info. Now my problem is my MBOX won't show up anymore - my USB drivers got updated during this process and now it refuses to show up other than "Unknown Device" -kd |
Crash when idle | Stig Eliassen | Pro Tools TDM Systems (Mac) | 5 | 04-04-2012 09:32 AM |
Pro Tools|HD 9 causing system crash when idle? | fisherking | macOS | 2 | 02-13-2012 12:25 PM |
When system left idle, I get an audio clock error | jmo1112 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-18-2011 07:50 PM |
CPU error (-9128) after system sits idle for a min | mix2much | Pro Tools M-Powered (Win) | 4 | 03-05-2007 08:45 PM |
Crash when idle | l anthony johnson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-24-2002 02:02 PM |
