Old 06-26-2021, 05:28 AM
Default coreaudiod (Not Responding)
This may be unimportant, but I'm interested.......
I'm seeing coreaudiod (Not Responding) in the activity monitor when the Carbon is connected. Sound still seems to be coming out of the Carbon though.....
MacOS 10.15.7, Mac Pro 7.1, 16-core, 48GB RAM. PT is version 2021.6.0. Carbon firmware is 1.0.1.2106111846A
Happens whether PT is running or not. Sound plays from PT and from third party apps (browser, Audirvana, QuickTime).
Old 06-26-2021, 05:55 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: coreaudiod (Not Responding)
Don't know haven't looked in the Activity Monitor since as you note it works fine with third party only playing and also when PT is open on Carbon
I have a question about your system line ,, how are you determining what your firmware version is ?
System :
Enjoy the Journey
.... Kev...
Old 06-26-2021, 06:03 AM
If you launch PT, select the Carbon as your interface, and go to Setup -> Hardware, the Firmware version is shown at the bottom left of the dialog box.
Old 06-26-2021, 03:45 PM
K Roche's Avatar
Ha I never even noticed it there thanks
System :
Enjoy the Journey
.... Kev...
Old 06-26-2021, 04:12 PM
FWIW I often see this too when using DVS or AVB on my Mac (same Mac and OS release as you). I suspect “working as designed”. Might be worth reporting to Apple.
https://lukehoward.com/
Old 06-27-2021, 03:40 AM
Thanks Luke.
I suspect that this is one of the things that caused overheating of less powerful Macs and got fixed in one of the Big Sur releases, but as you'll see from my post in another thread (https://duc.avid.com/showthread.php?t=414703&page=3) I'm not clear what Avid's advice currently is for MacOS version when running Carbon + 2021.6
Maybe it will end up like the WiFi advice, where you must have WiFi on for iLok cloud, but must have it switched off for optimised performance.
Or Spotlight, which you must switch on unless you are doing a recording over 50 minutes, in which case you must switch it off.
Having the Carbon connected causes my Mac to consume an extra 30-40 watts of power continuously, even when not playing any sounds, so it's definitely having an impact, it's just covered up by the excellent cooling of the Mac Pro.
Old 09-06-2021, 07:18 PM
MattheWood MattheWood is offline
Hi there,
I am running the same OS as you, but on a 2020 MBP, and I am getting this coreaudioid (not responding) constantly with Carbon. Also, every once in a while all the CPUs spike on the System Usage page Pro Tools, when I'm just idle. Did you say this is fixed in Big Sur? My Mac runs much hotter while using Carbon for sure with 10.15.7... Thanks.
Old 09-06-2021, 08:51 PM
Ben Jenssen's Avatar
FWIW, just in case it means something to someone; I've learned over the years that processes in Act.Mon. that ends with a "d", usually means "deamon". So to me, it's pretty obvious that this process name is a shortening of "Carbon I/O deamon". Sounds like a pretty essential component, I think. It would probably reside in the "LaunchDaemons" folder in sys/lib. Deamons are launched at startup.
Old 09-07-2021, 01:09 AM
Originally Posted by MattheWood View Post
Hi there,
I've "upgraded" to Big Sur - I tried 11.2, 11.3, 11.5 and 11.5.1 and now on 11.5.2. I haven't noticed any improvement - Activity Monitor no longer shows the coreaudiod as red, but it has the same issue, which is essentially lots of CPU 'idle wake-ups' - so the CPU is constantly prodded into action - it never gets to stay in a low-power state for long. Once again, with all versions of Big Sur I've tried, my Mac Pro 7.1 consumes an extra 30-40 watts of power (all CPU) when the Carbon is connected (and powered on), so I don't believe that Big Sur has really helped the fundamental problem. [I'm also on PT 2021.7.0 now, but I don't think that makes any difference either].
It may be different on a laptop, I don't know. I can't say I like the look of Big Sur and it feels less snappy than Catalina, but PT performance seems about the same.
Try sending a DM to Kyle Splittgerber or Mark Corbin - both from Avid - to see if they can help diagnose and improve your problem.
Dominic
Coreaudiod errors on startup hunter_aran macOS 1 01-09-2013 06:17 AM
PT 8.0.1 not responding NEED HELP keytone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 06-15-2010 05:43 PM
coreaudiod (Not Responding) Grant@2020sound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-13-2009 08:44 PM
coreaudiod (not responding) Ziko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 10-13-2009 09:10 AM
coreaudiod not responding - PT8 install Rich Breen Pro Tools TDM Systems (Mac) 1 02-10-2009 11:59 AM
