How\'s this mix?
Hello!
I am looking for some feedback on the mix of this tune. http://www.barelypink.com/promo/strongestone.mp3 Thank you! Brian |
Re: How\'s this mix?
I listened on headphones only. It sounds perfect to me. I'll try to listen on monitors later today, but so far, excellent level balance, guitars pannings, clarity...the drumset sounds a little "far" but that's a choice.
Sounds to me like an excellent job. |
Thanks David!
I am troubled by how the falsetto chorus part sounds, but I am not sure what to do with it. I amy try singing it differently. I am thinking it doesn't sit right in the mix. Thanks again, Brian |
Supe, overall great mix. I agree that the falsetto isn't quite right but not necessarily the way you sang it. I'd try doubling and then panning it hard left and right (and shift one side but a few ms to give it some very subtle space). You could also apply light eq to the OOH OOOHs to differentiate them a bit from the rest of the chorus. I also thought the oohs were a bit too forward. Other than that, I think you nailed it.
************ Steven Vertel Mixing / Mastering Engineer High Rock Records & Studio NYC http://highrockrecords.com |
I love the drummer of your group!
All instruments sound great and tight. I'd love to know what kind of compressor you used. |
Maybe that comes from the fact that your normal voice is loud and sung from far away from the mic, while the falsettos are soft and sung from close to the mic, hence more present? Have you tried singing the chorus from further away from the mic? But again, maybe just a little compression on the OOH (distance from the mic=compression!) and adjust the level carefully. I think the problem might just be the "attack" of the first OOH. Try playing with the automation if you don't like the idea of compression. |
Thank you for the feedback!
I will try your suggestions for sure! Brian |
Thank you Nori!
The drummer actually is the mix man! He used the Channel Strip plugin on all the drums. Thanks! Brian |
What is the Mix Man? Is it a drum machine??
If so, that's amazing. To me, the song sounds like you guys are playing it all together. |
I like it. I'd like to know what pre amp you're using for vocals, guitars etc. Are you using PODs for mic up amps? Good job. What mics?
tim |
PT 10.3.3 anyone? How's it going out here? | boogiemotel | macOS | 27 | 01-16-2013 09:34 PM |
10.4.10 How's it been? | tripit | Pro Tools TDM Systems (Mac) | 7 | 10-05-2007 02:01 PM |
How's your IRQ? | Rock_Artist | Pro Tools TDM Systems (Win) | 1 | 01-18-2006 10:09 AM |
How's The A to D on the ISA 428 | Carl Z | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-30-2004 05:56 PM |
001 and 6.4?? How's it going | cliepe12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-20-2004 08:41 PM |
