My panning NOT working... help!!
Ok, heres my problem. when i get done recording vocals, i try to pan it from the mixer but it never works< it stays in the middle(even with automation).
Im working withrotools LE 7 for mac, and i have a rack 003. and the input of my tracks is: analog 1-2 someone pleease help me!! thank you |
Re: My panning NOT working... help!!
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
I did it but still nuttin
what if you show the Pan Automation overview for the track?
is the automation written? what happens if you draw some pan action in? is Automation Suspend checked in the Automation window?
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Just curious, why is your input choice 1 AND 2? A vocal is usually recorded to a MONO track.
nutinssss working
i do record on mono
Can you show us a screen grab of the channel?
Do you have the mono button enabled on the 003?
https://www.facebook.com/petermartinssongroup/ |
If the actual input on your track says 1 & 2, then you are recording to a stereo track, whether you realize it or not (output should usually say 1 & 2).
When you go under track menu to create a new track, make sure you select mono. Assuming this is the problem, and if you don't want to redo your vocal, go under the track menu and choose split into mono. After you do this, select one of the tracks and delete it. Now you have a mono track. And as Petmar said, make sure the mono button is not pressed (should not be lit). |
panning in Reason not working when audio interface is connected | violent vickie | Pro Tools M-Powered (Mac) | 0 | 11-15-2011 01:15 PM |
Panning not working in M-Powered 7 | e07723 | Pro Tools M-Powered (Win) | 0 | 06-30-2010 02:27 PM |
panning | drummerjh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-22-2005 07:58 PM |
panning in pt | optymusblu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-11-2003 10:39 PM |
Panning!? | Dan M. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-04-2002 12:10 AM |
