Old 10-16-2021, 07:57 AM
ejsongs ejsongs is offline
Default Looking for best time stretching for pt in 2021
Looking foo Best time stretching in 2021 for pro tools:
Pitch n Time 3
X form
Zplane elastique
Waves Sound Shifter.
I currently own xform and Sound Shifter. Xform takes forever and a day. Looking for best sounding with zero artifacts. Mainly for changing tempo on background and lead vocal tracks, changing tempo on my mastered mixes before uploading to streaming services and time stretching loops with tce tool.
Elastic audio is cool for certain things but can leave way too many artifacts. Is it worth investing in pitch n time 3 pro/le or elastique or maybe both? I just want great results and as much as I rather not bite the bullet I will if I have to.
Thoughts?
Thanks,
Ej
Old 10-16-2021, 08:20 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Looking for best time stretching for pt in 2021
Serato has one of the worst support out there, unless you are DJ and buy their bread and butter stuff. Don't hold your breath when they would be Apple Silicon compatible...
Janne
Old 10-16-2021, 09:32 AM
EGS's Avatar
EGS EGS is offline
a recent conversation: https://duc.avid.com/showthread.php?t=417246
Click for audio/video demo
Click for resume
Old 10-17-2021, 01:18 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
check this out... 6 Of The Best Time And Pitch Manipulation Plugins
Hope it helps.
Mike
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
Old 10-17-2021, 03:41 AM
noiseboyuk noiseboyuk is offline
Pitch n Time 3
X form
Zplane elastique
Thoughts?
Thanks,
Ej
To this day I've not found anything to top the iZotope Radius algorithm. AFAIK however this isn't available as a direct plugin for PT - I wish it was. I usually export to RX which uses it. Adobe Audition uses the same algorithm.
For use with the timestretch tool, X-Form can be ok, it's certainly miles better than stock.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 10-17-2021, 05:06 AM
Marsdy Marsdy is offline
Pitch n Time 3
X form
Zplane elastique
Thoughts?
Thanks,
Ej
I have the ones you list except PnT. To me it’s very programme dependent, algorithms work some of the time. I have elastique as my default in preferences but very often try one of the others if I’m not happy with the results. Occasionally even Avid’s TCE algorithm wins!
Dave Marsden
UK
Old 10-18-2021, 02:22 AM
Marsdy,
That is what I am afriad of...which basically means i will need to get them all.
Ej
Old 10-18-2021, 02:23 AM
Marsdy,
That is what I am afraid of...which basically means i will need to get them all.
Ej
Old 10-18-2021, 02:53 AM
This is all why I use Radius the majority of the time. The others aren't as good - unless it's super-simple material I just export to RX and be done with it.
Guy Rowland
Old 10-18-2021, 10:27 AM
Eric Lambert's Avatar
Pitch n Time ranks supreme in our experience (music composition and audio post). We do quite a lot of expansion/compression and cry like babies when we're forced to work on machines that don't have P'n'T installed. It's nearly always the most transparent of the many options available. The cost of admission can be steep, but worth it, IMO.
HTML code is On
Time Stretching spaceman Tips & Tricks 21 04-16-2006 11:30 PM
Time Stretching FatBelly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-21-2006 01:55 PM
time stretching? josh002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-06-2004 10:23 PM
Same bpm and Time Stretching ecsmix General Discussion 0 10-15-2003 04:10 PM
time stretching souldier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-13-2002 12:53 AM
