2022 update: routing Mac Built-In audio to PT?
A long-term challenge for users of PT/Avid hardware is routing the Mac's Built-In audio into ProTools. When PT is open, it doesn't easily allow you to route other apps' audio into the PT world. Source-Nexus (from Source Elements) is designed for this purpose, because they offer an AAX plugin which can be used to grab that audio stream, but, historically, there haven't been many options. Nexus is what we use, but it's expensive, and this should be an easier task to figure out.
Now that it's 2022, is anyone aware of a new option? Perhaps new Blue Cat products? Rogue Amoeba products? |
Re: 2022 update: routing Mac Built-In audio to PT?
You need Blue Cat's Patchwork to do this and the plugins that are found in /System/Library/Components/CoreAudio.component
Load AUNetSend into Audio Hijack or anything else that loads AU plugins Load AUNetReceive in PT
MacBook Pro Apple M1 Pro 32GB Mac OS 12.6.2 Pro Tools Ultimate 2022.12 _____________________________________________ |
Is there anything I need to know about the configuration of AUNetSend once loaded into Audio Hijack? I haven't been able to try it yet and don't know what options might exist, I'm just asking in advance so I'll be prepared.
I got it working, but it's in mono. I'm currently trying the demos of both Patchwork and Audio Hijack -- maybe mono is a limitation in one of them?
I do this with a rather grisly cheat. I set the Mac audio out to 'digital out' and have an optical cable from it to my Behringer SRC2496, and balanced +4 analogue from there to a pair of Pro Tools inputs. And I don't have to worry about a difference in sample rate/bit depth between my open session and whatever I'm ingesting, and I don't have get involved in clock sources.
Works well for me but I happened to have the SRC2496 anyway, and I actually rather like that device - one of Behringer's better products. (And I have a CD player on the SRC2496's S/PDIF input and a DAT machine on the AES/EBU input so it's a digital patchbay of sorts.) Only downside is there's a slight click as I start the play-in while the SRC2496 locks to optical and detects the sample rate. This is because unfortunately there's no signal coming out of the Mac's digital output until it starts playing so there's nothing for the D/A to lock onto.
-- Justin Mark Hill https://theotheroperation.com Apple Mac Pro 6,1 late 2013 2.7Ghz 12-Core Xeon E5, 64GB RAM, D500 Graphics, OSX Monterey 12.7.1/Pro Tools Ultimate 2023.12/Presonus Quantum 4848 Thunderbolt 2/Digidesign C|24/Focusrite ISA430 MkII/SPL GoldMike |
turns out this is even simpler if you use the routing on your audio interface and audio hijack
Another option: If you audio interface has loopback you can use that.
There's also another app called GroundControl ROOM that will do this too. Set it as the Playback engine for Pro Tools and for System sounds. Set the input to GroundControl ROOM 1+2, Mute the track, and record. GC ROOM does a lot more, I have a video about it here, but I don't cover the recording in DAW part in the video.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Jan 2022 Apple Security Update bricking display again | OAG | Avid S1, S3, Dock and Control App | 2 | 01-04-2022 09:46 AM |
Pro Tools Ultimate Perpetual License (Update + Support expires 2022) | starlingmusic | Buy & Sell | 0 | 04-17-2021 09:20 PM |
Mac Pro's built in digital audio & its audio clock | Jimmix | General Discussion | 4 | 07-30-2014 05:56 AM |
003 ADAT routing since 8.03 update | nevertold | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-05-2010 08:30 AM |
Can I use built-in OSX Software Update with PT8 and 10.5.8? | Robbie Hollywood | Pro Tools M-Powered (Mac) | 1 | 12-22-2009 09:33 AM |
