MPT2, but no Structure LE <?>
I was having issues with Eleven free not showing up. I decided to upgrade the MPT1 to MPT2 and get Eleven LE plus the other plugins for only $50.
I installed MPT2 and now have Eleven LE. Great! But it still loads Structure free version. Am I mistaken, or should'nt it be loading the full version of Structure now? (Yes I trashed the prefs using the Digi utility). Thanks Van
vandergraf.net "All the truth in the world adds up to one big lie" :: Bob Dylan ¯ |
Re: MPT2, but no Structure LE <?>
Not the full varsion. You should have Structure LE. Check your iloc to be sure that the auth. is present. You can always download Structure again if you can't find it.
http://www.digidesign.com/index.cfm?...74&itemid=5222
Thanks Tom, Yeah my ilok says "Structure LE" But it loads the Free version.
I will re-DL it and install. Thanks Van
If I remember correctly, I had to go into c:\program files\common files\digidesign\dae\plug-ins and manually remove the structure free dpm and rsr files.
Hope this helps. Peace!
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
The re-install worked ! Thanks again Tom.
Van
Glad I could help.
P.S. Denander11 is correct about pulling the free version manually if it bothers you.
from PTLE8 with MPT2 to PT10. is it all for the best? | jax72 | macOS | 7 | 04-16-2012 03:37 PM |
M-Powered not seeing MPT2 | useyourwood | Pro Tools M-Powered (Win) | 0 | 02-28-2010 12:03 PM |
problems - MPT2 on LE 7.4.2 | rpm1nj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-09-2009 10:38 AM |
So is it safe now t upgrade from MPT to MPT2? | Jeff_C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-22-2008 10:58 PM |
mpt2 install | conviction | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-21-2008 04:52 PM |
