DAE error -1103 was encountered.
I am running PT version 6.4 on a windows machine. Pentium with XP. Using 888/24 i/o. Nothing external attached except a 4 Gb thumb drive only when I need to get files to my team. And then I only connect it, dump the files and pull it.
I am getting the above mentioned error message as well as: •1103 Not able to aquire the hardware and must exit now. •1103 Could not complete you request because: Access violation occurred. And other similar -1103 messages. It has always worked fine. When I restart and stay in ProTools it seems to be fine. When I exit and re-open without restarting the mayhem begins. The only thing I can think of that has changed is I changed the playback engine settings at one point when I received the message "buffer overrun occurred" I believe ti was. I have since switched back. When I switch to 1 DSP 32 voice it will work for awhile then start up again. Also when I have attempted to bounce to disc, as soon as I try the bounce it -1103's me again. ? Thank you. |
Re: DAE error -1103 was encountered.
Additionally, I have a clear side to my computer and have noticed that on the side of the Mix cards there are lights. The top card has a RED light and a yellow light. The bottom card has a GREEN light and a yellow light. ?
Digitest error -1103 | dwaynedelario | Pro Tools HDX & HD Native Systems (Mac) | 20 | 01-07-2014 04:53 AM |
error -1103 | cbcarch | Pro Tools TDM Systems (Win) | 0 | 01-03-2008 10:17 AM |
DAE 1103 or ID_1103 Error | Digivan | Pro Tools TDM Systems (Win) | 2 | 04-18-2002 03:39 PM |
DAE error was encountered while trying to connect (error #-7101 | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 1 | 06-07-2001 12:45 AM |
message ID=-1103 error | polkbrosmusic | Pro Tools TDM Systems (Win) | 1 | 05-15-2001 11:52 AM |
