Error while loading 'EUCON' controller personality - WIN10
Hello all,
After weeks/months of working without any problem, I suddenly get the message: 'Error occured while trying to load the controller personality 'EUCON'' when trying to activate the EUCON Control Surfaces in the Peripherals>Ethernet Controllers System: Win 10, Duodecacore i9, 128 Gb ProTools 2022.12.0 Eucontrol 2022.12.0.81 EUCON Version 4.10.2.81 2x S1 + 2x Android Control Tablets 1x Dock 1x iPad Air 2 All hardware appears neatly in Eucontrol software. But suddenly no communication between ProTools en EUCON hardware. Anyone knows where the 'EUCON controller personality' is located on WIN 10 and how to remove and/or replace it? (If I know which file(s) is/are involved, I might be able to locate it on a recent system-back-up) I've tried removing/reinstalling both PT 2022.12.0 and Eucontrol and checking firmware. And of course warm and cold system-restarts... TIA Huibert |
Re: Error while loading 'EUCON' controller personality - WIN10
i don't know if these can be related but today i saw this message for the first time.
After this, in eucon had to manually add my 2x S1s, Dock and 3 tablets. I think it's working fine, though i just started working...we will see. |
No, this means your network is not setup correctly. You have two network adapters set to the same subnet. Computer doesn't know which to use and can cause slowness and dropped data.
maybe this is the cause for softkey errors in my system. i have 3 networks(mac pro 6.1 with 2 ethernet outlets and 1 more ethernet outlet on thunderbolt dock), 1 for internet and 1 for eucon and the 1 on thunderbolt dock for neumann subwoofer. And yes, they have the same subnet mask: 255.255.255.0 How can i change it for ethernet 2 which is used for eucon? |
Hi, Same subnet mask is fine. That doesn't not denote the subnet. With a subnet mask of 255.255.255 the subnet is defined by the first 3 numbers of the IP address of your nics. So if you have more than one NIC with the same first 3 numbers, then you do have two NICs on same subnet. For example if you have two nics with 192.168.1.xxx then you have two nics on same subnet. If you do have two actual NICs on the same subnet, get rid of one. There is no point in having two NICs connected to the same subnet. Not referring to WIFI here, simply physical ethernet NICS. |
I do have some problems with eucon and cubase but they mostly seem like bugs...but this error message today (which popped up for the first time) made me thing maybe those issues are not bugs and network setup errors on my end. though beside the bugs, softkey droupouts my system/eucon works. so...from your message, what i understand is: my subnet mask settings are fine. note: @huibertnoon, sorry i derailed your post, before you found a solution to your problem. |
no, ethernet 2 goes to a switch used for eucon. the broadcom (which is ethernet port of belkin thunderbolt dock) goes directly to neumann kh750 subwoofer.
Please post both IP address of these from your workstation ethernet adapters
Error during loading controller personality EUCON | [email protected] | Getting Started | 1 | 11-21-2021 08:30 AM |
error loading controller personality eucon | guitarhead | Avid S1, S3, Dock and Control App | 2 | 01-04-2020 11:26 PM |
EUCON error loading controller personality | guitarhead | Pro Tools 2019 | 0 | 01-02-2020 04:27 PM |
EUCON error loading controller personality | guitarhead | Avid Pro Mixing General Discussion | 2 | 01-01-2020 01:08 PM |
Error Loading controller personality | Old School Audio Guy | Artist Series | 4 | 02-04-2013 09:49 AM |
