Old 04-17-2011, 12:56 PM
Lonefse Lonefse is offline
Default bypassing mbox 3 preamps
Can you bypass the mic preamps on the Mbox 3? Not the mini or pro...just the Mbox 3? I've read that you could through the SPDIF connections (I want to confirm this also) but was also wondering if mic > preamp XLR to Mbox XLR (since the line input is there as well) would work by not turning on the mbox preamp? Thanx in advance
Old 04-17-2011, 01:02 PM
Dism Dism is offline
Default Re: bypassing mbox 3 preamps
Originally Posted by Lonefse View Post
Can you bypass the mic preamps on the Mbox 3? Not the mini or pro...just the Mbox 3? I've read that you could through the SPDIF connections (I want to confirm this also) but was also wondering if mic > preamp XLR to Mbox XLR would work by not turning on the mbox preamp? Thanx in advance
If you're going through XLR, then you're definitely going into the preamp. There's no way to "disable" it. As far as I know, the only current MBox that allows you to go in true analog line level is the MBox Pro.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 04-17-2011, 05:21 PM
Yes indeed. One way around this is to use the SPDIF input with something like the API A2D. Just be aware that the MIX knob has no use with the SPDIF input as it only operates on the analog inputs. There may be more options with the newer Gen 3 Mboxes and the new software that comes with them(the monitoring software, not Pro Tools).
Bypassing mbox preamps brian4411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-02-2008 10:19 PM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2007 09:55 AM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2007 07:52 AM
Bypassing MBox preamps - direct in Ian-H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-25-2006 05:16 AM
bypassing preamps on mbox Rod Elledge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-30-2004 07:59 PM
