Old 09-12-2022, 11:22 AM
M-Sounds M-Sounds is offline
Default Midi editor greyed out!!
Hello,
Recently I purchased a 1-year subscription to Pro Tools Artist, and I'm getting to know the program a little bit, but I'm having this issue that my midi editor is greyed out when I try to use it in an Instrument track.
So I opened an Instrument track with the plugin Keyscape. Then I would like to fill in some notes inside the midi editor but nothing is happening!!?
I try to click on the keyboard on the left-hand side of the midi editor but there is no sound either.
Can somebody help me with this issue?
- Mahmoud (M-Sounds)
Old 09-12-2022, 04:56 PM
Default Re: Midi editor greyed out!!
I'm no midi expert, but AFAIK, the virtual keyboard is for reference and not for inputting notes. If you set the Instrument track to Notes view, then you can drop notes on either the Instrument track itself, OR on the Midi Editor piano roll(using either the Pencil tool or the Smart tool). With the Instrument track in Clips view, you must go to the Midi Editor window to drop notes(maybe its me, but I wish the default view was Notes, anyway)
Old 09-12-2022, 05:44 PM
jeffro's Avatar
jeffro jeffro is offline
Welcome to the community.
The keyboard on the left of the MIDI Editor can be used to preview your VI, but to add MIDI notes... draw them in, play a MIDI Controller or use the virtual MIDI Keyboard (found in the Window menu) while recording, etc.
If that's not triggering sounds perhaps your Playback Engine or hardware isn't configured correctly, or that track is not assigned to the VI? It would likely help to get more info, so please reply with screenshots of your Mix window (with INSTRUMENT enabled - click the View Selector to then check/enable that) and Playback Engine window (Setup menu).
File Type: png Screen Shot 2022-09-12 at 5.08.30 PM.png (36.8 KB, 0 views)
linkedin
Old 09-13-2022, 09:49 AM
When I'm using the ''Mini grand'' plugin inside the instrument track, I can see the metering going up, but no sound!!
Here are a couple of pictures.
Old 09-13-2022, 10:53 AM
K Roche's Avatar
K Roche K Roche is offline
First your screen shot is blurry and I can't read the text in it. Depending on your display you may want to reduce the resolution one step for screen shots
also as suggested do a screen shot of your mixer window
If you are getting signal from the mini grand showing in the track meters then you need to check your routing or your midi preferences and see what your "Default Thru Instrument" is showing
I always select "first selected MIDI track" that way with multiple instrument tracks I can just switch back and forth highlighting the track of the instrument I want to hear .
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 09-13-2022, 11:27 AM
I have managed to fix the sound but still the ''Midi editor is still greyed out and I can't fill in notes!?
Old 09-13-2022, 11:36 AM
Yeah my bad about the picture.
But the issue is resolved. When I opened the midi editor it when to the click track instead of the instrument track I was using with the piano. I clicked the instrument track and I used the keyboard shortcut to go straight to the midi editor, thinking by myself it when to the instrument track.
Is there a faster way to go straight to the instrument track when highlighting it?
Thanks
MIDI Editor and MIDI Event Editor keyboard commands broken 12.4 HD Marsdy Pro Tools 12 5 01-31-2016 05:01 AM
Digi MIDI i/o Duplicated and greyed in Audio/Midi setup xxicjoy MIDI 69 08-02-2013 08:40 PM
Midi IO not shown in AMS or is greyed out. When greyed out no MIDI options in Tools drewsmith Pro Tools TDM Systems (Mac) 3 10-15-2011 06:21 PM
MIDI Greyed out? fpalmieri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-20-2006 04:49 AM
MIDI Greyed out? fpalmieri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-19-2006 12:06 AM
