Dante with aggregate device
I had a question about using Dante with Pro Tools. I'm not on an HD system.
I have Dante set to 64x64, and I'm doing a recording that requires 58 channels. I'm trying to use an aggregate interface to monitor Pro Tools, but I can't seem to figure this out. If I create the aggregate device to have a UAD Apollo twin first, I can use 1-2 out and hear pro tools. Here's the problem: I need Dante's inputs 1-14, but they're being eaten by the UAD aggregate. If I make my aggregate with Dante first, I get the channels I need, but then no play back. Is there any way I can route the sound out of pro tools to my UAD? I think it has something to do with the 64 I/O max, but is there no way to disable some outputs to make use of the Apollo's 1-2 out? |
Re: Dante with aggregate device
CoreAudio aggregate devices simply appends the device IO together.
Pro Tools (Studio) simply trims IO off the end of the total aggregate past 64 IO. If you need to remove input ports off the Apollo Twin you would do that in the Apollo Console. You need to RTFM Console documentation about the Console I/O Matrix. Or even better don't rely on Aggregate I/O... but that needs Dante digital converters or a Dante interface. |
When aggregating, doesn’t it allow you to select/deselect the hardware channels you want to include in the aggregate interface? There’s no reason you have to include all 14 channels of the UA. Customize your aggregate in the AudioMIDI settings.
EDIT: Ignore my ignorant answer. I was thinking how the onboard I/O appears as separate entries. Third party hardware does not. Sent from my iPhone using Tapatalk
And again aggregate IO is arguably not the "best" way to do this, it may or may not work reliably. AFAIK Avid still does not officially support Aggregate I/O expect for adding built in output (or whatever it's called) to an interface. So test well. |
You could do this with Dante Via. Simply route the DVS monitor channels from pro tools to the UAD hardware within Dante Via. Forget making an aggregate device and just use DVS as your playback engine in Pro Tools and route accordingly.
https://www.audinate.com/products/software/dante-via |
It’s not possible to use Via and DVS simultaneously on the one system. Only one or the other.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Are you saying I could set Dante Virtual Soundcard (DVS) to have two less outputs (63-64), then setup an aggregate with UAD Twin, and then at that point, Pro Tools will see 63-64 (Previously Dante) as the Apollo Twin's out 1-2? |
Ahhh, thanks for the correction. Then perhaps Loopback is a solution.
--- And if you made your Twin a (grr edit typo:) 0x2 interface and put it first in the aggregate... wouldn't that just achieve what you want???? And I'll repeat again aggregates may or may not work reliably. Last edited by Darryl Ramm; 08-28-2022 at 12:21 PM. |
What is an Aggregate Device ? | Panacci | macOS | 1 | 06-18-2012 04:21 PM |
Why can I only see one aggregate device in PT9 | multivir | macOS | 1 | 02-13-2011 07:58 AM |
Aggregate device trouble Snow Lep! Tascam US122 won't aggregate? | crizdee | Pro Tools 9 | 3 | 12-02-2010 03:17 PM |
OSX Aggregate device with 192 I/O | TheHopiWay | Pro Tools TDM Systems (Mac) | 5 | 12-03-2007 02:30 PM |
Aggregate Device? vs M Box | relgato | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-07-2006 01:23 PM |
