Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 10-05-2021, 07:25 AM
Armando Armando is offline
Default What’s the latency with VI’s(SD3, IR Loaders…)
Hello! What’s the latency like using VI native plugins(SD3, IR loaders, ..) using PT/Carbon??
Thanks!!
Armando
Old 10-05-2021, 08:33 AM
Default Re: What’s the latency with VI’s(SD3, IR Loaders…)
Same as most any other setup until someone comes out with DSP virtual instruments
Old 10-05-2021, 08:36 AM
RobertDorn RobertDorn is offline
Hi! From what I understood the latency with VI’s is as much as your current sample buffer in the playback engine + sample delay adding plug-ins on your VI’s chain + the D to A output. This is no different when running protools natively or with Carbon / HDX Hybrid Engine.
Would be kinda cool if AVID could implement something like Universal Audio did with LUNA for virtual instruments tracks: they make an exception for the first plug-in instance being native (the VI plugin itself) with the possibility to have DSP plug-ins in the chain after it. Also it’s session buffer independent so there’s always a low latency path with playing virtual instruments , wether you’re tracking in a fresh session or a full blown mix with native plug-ins that add 6000 samples of delay on other tracks.
The only exception is HDX classic on a HDX card system (not possible with Carbon which is only Hybrid Engine), who will let you add dsp plug-ins on a virtual instrument track. But still it’s dependent on your system delay with the playback buffer set in the playback engine.
Long story short: Carbon and HDX Hybrid Engine only take care of low latency audio paths independent from the playback engines sample buffer and have no direct benefit for low latency VI tracking.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
Old 10-05-2021, 08:44 AM
AAX DSP Virtual Instruments ain’t gonna happen. And with clever implementation it would also not be necessary. Unfortunately for now, if your Pro Tools native sample delay in your playback engine is 256 samples, then every record enabled instrument track will have those 256 samples of delay.
Old 10-05-2021, 09:35 AM
EGS's Avatar
EGS EGS is offline
Try buffer 64
Click for audio/video demo
Click for resume
Old 10-05-2021, 12:20 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
You'll be between 10-17ms depending on buffer for RTL for IR Loader. Roughly half that for VIs, since they only need the output buffer and delay.
Old 10-05-2021, 01:53 PM
Thanks for the real life numbers Matt!!
Armando
MIDI recorded latency after playing with no latency genebackmusic Pro Tools 12 8 01-19-2016 02:36 PM
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
