  #41
Old 09-10-2021, 03:16 PM
EddieJones's Avatar
Default Re: *******Fix for Apple Security Update bricking displays*******
Can you look here and delete everything (backup first) /Library/Application Support/Euphonix/UserSets/MC2User/MC_USER_SET_Root
  #42
Old 09-10-2021, 03:21 PM
operator operator is offline
I removed the whole Euphonix folder to the desktop
Would I need to delete it from the desktop as well?
  #43
Old 09-10-2021, 03:22 PM
EddieJones's Avatar
Ok, great..I have to go get my kids too....
  #44
Old 09-10-2021, 03:31 PM
I`ll have to try on Monday Eddie and get back to you, I`ve got to leave now. Thanks for your help!
I removed from the previous edit ;-)
  #45
Old 09-13-2021, 09:03 AM
Then restarted the mac.
  #46
Old 09-13-2021, 09:33 AM
EddieJones's Avatar
No need to delete it from the desktop.
  #47
Old 09-13-2021, 11:46 AM
Thanks for the confirmation. Any other ideas?
  #48
Old 09-14-2021, 11:10 AM
EddieJones's Avatar
Running out of ideas...So you uninstall, check remove all Apps and remove all prefs, delete that folder and restart. Reinstall, reboot and it still does it? Try taking EuControl out of autostart.
  #49
Old 09-14-2021, 02:04 PM
I tried de-selecting Auto-launch Apps, so EuControl had no tick next to it / restarted, problem persists.
FWIW. When it hangs, I can force quit / restart EuCon.
EuCon will run, Mix and Control work normally with mutes, faders and soft keys.
It`s only when I enter EuControl settings from the menu icon that the app hangs. This only happens with the MC Control in surfaces. If the MC Mix is the only surface, there is no problem.
  #50
Old 09-14-2021, 02:09 PM
EddieJones's Avatar
Its really strange, and you say this doesn't happen on your other partition. Maybe some corrupt disk permistions?
*******Fix for Apple Security Update bricking displays******* EddieJones Avid S1, S3, Dock and Control App 61 09-06-2021 11:52 PM
Do not load latest Security Update from Apple Park Seward macOS 5 03-12-2015 06:22 AM
apple security update 2009-002? nst7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-14-2009 11:45 AM
OK To Do Apple Security Updates? hitshack Pro Tools TDM Systems (Mac) 3 11-30-2006 07:29 AM
Apple's security update is out, should i update? Arvid Gunardi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-25-2003 09:00 AM
