32 bit depth, sample rate?
I was watching a tutorial internal mixi and the guy mention the best quality for the audio its 32 bit depth i was trying to get there on my protools 9 le and only i can go up to 24 bit there's anyway to set protools for that?
Thank a lot |
Re: 32 bit depth, sample rate?
It's not just about "getting there"... your interface needs to be able to convert at 32 bits as well. I don't personally know of any, and I imagine a truely 32 bit converter would not be an inexpensive one.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
The mix bus in Pro Tools mixes deeper than 24 bits. E.g 48 bit fixed in HD, 32 bit float in LE, 64bit float in HD native??? (see other threads here on that). It was the mix bus depth that your tutorial referred to not the interface A/D bits. Darryl |
I wonder why the mix engine is 32bit, but the file system and converter is only 24 bit ?
Seems like 8 bits are wasted ? Personally I think all the different formats 16, 24, 32 bit is confusing. There sould be one standard. Also I don't understand why mp3's don't support 24 or 32 bit format. And in audio converters why was 24 bit selected as standard over 16 or 32 bit ? |
Might wanna do some reading up on bit depth, then.
Regardless of what you're mixing in, the bit depth is only a deep as the DA converters allow. Unless your converters are capable of higher than 24 bit, you will only ever "hear" 24 bit.
Currently even the best 24bit converters do not reach true 24bit theoretical dynamic range. I think 18-20bit (120dB) or less will be about the very best you will get in he real world. Just asking because most modern pop-music has about 5-2dB (or even close to zero) of dynamic range. Even the most dynamic classical music pieces don´t have such a huge dynamic range. Even if you had such a dynamic range at your disposal you would need a super-duper-extremely-quiet-super-isolation-listening room to even be able to hear sounds lower than the quietest room tone in the very best studios. On the other hand you will need serious ear-plugs for the loud parts of the music when it hits full scale.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
In addition to Frank's points above,
32bit floating point is 24bit. The term "floating point" comes from the fact that from the MSB (Most Significant Bit) to the 23rd bit are fixed. The 24th bit, or LSB (Least Significant Bit - though when it's causing this much of a stir, you might call it the most significant) is continually variable, and can represent the final piece of code to resolve a 24bit, all the way up to a 32bit dynamic range, depending on what it detects. So it just interpolates between the know values of the 23rd bit and whatever the floating bit last represented - a bit like key frame animation. It's of no real use at the A/D stage, but it makes for a much more robust mixing environment. Hope that helps. |
Thanks.
thank a lot to everybody the name of the tutorial its internal mixing this guy work with cubase and nuendo and yes the guy said 32 bit floating its kind of confusing ,but carl kolchak said 32 bit floating point is 24 bit ...
thank a lot for the information to everyone regards. |
Bit Depth & Sample Rate... | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-10-2017 01:16 PM |
bit depth, sample rate? | badda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 02-21-2007 10:49 AM |
sample rate and bit depth | arcada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-10-2005 08:53 AM |
Plz Help! Sample rate and bit depth | Mekko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-16-2005 08:09 AM |
sample rate and bit depth | dracos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-02-2004 07:41 AM |
