Did I make a mistake buying mBox? Please help
I am new to PT/mBox having a bit of a learning curve. Here is the problem I am trying to record an analog instrument in audio track, I've done this before and it worked. Now there is no signal coming through. I can hear the Keys through the headphones(thought the mBox) but no indication it's coming though to the PT. When I record enable the track I hear a pop and the level indicator starts showing a steady yellow line as if it is getting a signal. When I press space bar with that track R-enabled, every other track sounds as if it is doing though "bit crusher", garbled. It is Very frustrating. I am actually thinking of returning the mBox and getting Ableton Live with the firepod, if it's possible. Before, I worked mostly with garageband just plugging directly into the computer getting the sound quality that is far better, clearer and stronger than what i am getting with mBox. Surely I am doing something wrong..... It is set In-1, Out 1-2 in I/O I tried everything.... I realise you might need more info but this is all I have. Please help. I don't want to be disappointed with PT (and have my money waisted ) Thanks |
Re: Did I make a mistake buying mBox? Please help
Yea your gonna need more info than that man. Like what Pro Tools version are you running? Which Mbox do u have? 1, 2, Pro, Mini? Ive owned an Mbox (1 and Pro) for the last couple of years and really loved em. I have a feeling that if you get whatever problem your having sorted out your gonna like it too. BUT i needs more details...
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod Terrarium HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2 (3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console |
I have MBox2 PT7.0 on G5 Imac.
When a track is r-enabled I have to desable Record in order to hear what has been recorded, Is it normal? |
there is a switch that puts the input in auto-input. It is in one of the pull down menus. Or option>K
this will fix it. rich |
Help me not make a mistake | KrisHeinold | General Discussion | 13 | 11-16-2010 10:43 AM |
Did I Make A Mistake Buying an ICON? | sburrows | ICON & C|24 | 6 | 09-11-2008 08:42 PM |
did I make a mistake buying a midisport? | Tito Ricci Arballo | MIDI | 3 | 08-28-2007 05:12 PM |
did i make a mistake????? | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-05-2002 10:14 AM |
Did I make a BIG Mistake? | OrbachPageSyndicate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 08-22-2000 02:27 PM |
