Old 03-10-2015, 01:44 AM
Becharax's Avatar
Becharax Becharax is offline
Default Eleven Rack ReAmp HELP !
Hello Folks,
I am having Problems ReAmping With Eleven Rack !!
Can Someone Please Help ??
There you go My setup:
Using Pro Tools 11
Main Interface: Symphony I/O with 2 line level inputs.
Eleven Rack Connected to the SPDIF of my Symphony
Focusrite ISA TWO with the 2 outputs connected to analog line inputs of my symphony.
A Guitar Connected to the DI of the Focusrite.
(I recall that in order to reamp with eleven... there has to be a cable coming out of the output to Amp from the 11rack to an analog input on my main interface ...) but as you see that the 2 inputs are occupied with the outputs of the focusrite ...
Is there any turn around for that ??
Help ... Thanks
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 03-10-2015, 02:13 AM
Becharax's Avatar
Default Re: Eleven Rack ReAmp HELP !
I was actually watching a Youtube Video by Benoni and he insisted on connecting a cable via analog ... I would love to reamp with a separate interface only with the SPDIF cables connected
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-10-2015, 02:54 AM
Becharax's Avatar
There is no such section in the manual stating How to reamp with eleven when used with a main interface ...
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-10-2015, 03:17 AM
Becharax's Avatar
But the Manual I got is the version 9 ...
Do you have a link for the latest one ? I will be Grateful
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-10-2015, 05:18 AM
junkgear's Avatar
junkgear junkgear is offline
Please read through the Eleven Rack Info thread to help you find useful information on the 11R.
The latest manual is Version 9. The manuals can be found here
The section you want in the manual is Chapter 7 - Reamping
Will
System Details
Old 03-10-2015, 05:37 AM
Becharax's Avatar
junkgear I have read that ! there is nothing that explains on how to reamp when the rack is connected as a slave through digital connection ...
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-10-2015, 07:19 AM
Becharax's Avatar
Please Check This Article:
http://avid.force.com/pkb/articles/e...ow_to/en352019
Check the section where they talk about: Re-amp Using the Eleven Rack Processors
under step 5: they say Eleven Re-amp.L** (if it's a mono track)
But how can I assign it to this when in outputs all I have are the analog outputs of the symphony ??
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-10-2015, 07:28 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
The reason that Brian is connecting the analog cable is because he is recording the RIG in stereo using S/pdif.
If you want the DRY guitar sound PLUS the stereo RIG, yes you need the additional cable. So if you have already recorded your RIG and not your DRY signal, you really don't have anything to re-amp
Otherwise you can split S/pdif and record mono RIG and mono DRY with only the S/pdif.
I'll echo what has been said about recording your guitar using 11R as the interface. I do that quite often. Turning off the 003 and using the 11R as the interface. Works really well and is a piece o' cake.
I'll also echo spending time with the manual. It truly IS one of the better manuals that I have seen from Avid.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 03-10-2015, 07:42 AM
Becharax's Avatar
Ok let me get things straight ... I have an audio recorded in Dry ... regardless whether it was recorded with eleven or not ...and I want to add the effects of my rack to that audio track ...
Do I need that extra cable or not ??
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-10-2015, 08:53 AM
Cowboy Bob's Avatar
Short answer is NO!
Look at page.....I think 86...yes 86 of the 11 Rack manual. It is very clear how to re-amp a track that is already recorded into Pro Tools.
Bob
Can't ReAmp in Eleven Rack (output inactive) jlg75 Eleven Rack 4 02-07-2014 09:10 AM
cannot reamp using eleven into fasttrack c600 into pro tools clydey Windows 8 08-02-2012 03:31 PM
eleven rack reamp question anth Eleven Rack 2 02-24-2012 08:17 AM
How to reamp with eleven rack???? TeamContra Eleven Rack 3 09-07-2011 05:22 PM
Eleven Rack Hardware Reamp negative latency AKA Early??? finkbmx Eleven Rack 1 03-01-2011 04:34 AM
