URGENT: Crashing on launch in middle of massive project!!!
Please help if anyone can. I finished one session and opened another. In the middle of the session opening, I got a kernel panic...
Hadn't seen one in a while, but it happens. i restarted, now EVERY single time I try and launch ProTools 9, i get a kernel panic on the DAE section of the startup sequence. Any thoughts? Willing to try all sorts of stuff as I am in the middle of a massive project. thank you!!! russell
www.russellwolff.com I produce things @ www.krazypopstudio.com Endorsements and affiliations: MikTek Microphones, AVID, Klotz Cables, CAD Headphones, ToonTrack, Parker Guitars, Taylor Guitars, Steven Slate, Seymour Duncan Pickups, D'Addario, Bugera; Dangerous Music, Digidesign, Focusrite, IK Multimedia, Altiverb, Focal Monitors, and SurgeX. Pro Tools 12.4 HD, MBP Quad-core 2.5Ghz i7, 16GB RAM, UAD-2. Interfaces: UA Apollo 8 |
Re: URGENT: Crashing on launch in middle of massive project!!!
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
yes, sorry. should have mentioned that. but i will run through all those steps again for good measure.
left the studio for a bite. re-did all the steps. the kernel panics seem to have gone away.
but strangely getting some unexpected quits of the program. that IS actually progress though. thanks rw
What are your setup specs? There is nothing to go on here.
Your site says you are using Leopard 10.5 and PT8.
Mac Studio M2 Max 12-core CPU, 38-core GPU, 16-core Neural Engine 64 GB memory 2TB Solid State Drive Thunderbolt 4 Sonoma 14.1.2 Pro Tools 2023.9 Universal Audio Apollo 8P (TB3 Option Card installed) |
Try holding the SHIFT key while you open the session. That will make all plugins inactive. The make plugins active again, row by row until you figure out which plugin causes the issue, and either update or remove that plugin.
wow, have to update that. OLD OLD info ;-)
So do we have to guess or are you going to tell us? We all really do need that info to help.
Of course you need to check all your plugs.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
i was working... it happens ;-)
i am in the middle of this project and won't have a free day til late december. anywho... like i had said, the kernel panics seem to have gone away for now. I found someone else on another forum that was having the same issue. PM'd him to see if his went away as well.
can someone PM me where it says I am using PT8 and 10.5?
thanks russell
Urgent Help, MAc Gurus - DVI1 stopped in the middle of mastering job | Alécio Costa | Pro Tools TDM Systems (Mac) | 21 | 10-09-2010 02:29 PM |
Upgrading from PTLE 5.3.2 in middle of project | OneMadSon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-04-2006 02:08 PM |
Upgraded Massive pack 4 for PT7 , problems Launch | andre tchmil | Pro Tools TDM Systems (Mac) | 5 | 11-29-2005 04:07 PM |
Upgrading in the middle of a project (6.0-6.7) | johnjm22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-31-2005 10:54 AM |
serious 002 Problem in the middle of a project | jackdaniels | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-25-2005 06:46 AM |
