Burning at 1x with Nero
I am burning a master cd that will be used for duplication.
My version of Nero (and burner) seems to only offer 8x as the slowest burning speed. Is it possible to burn at 1x with Nero? Is it any detriment to the CD to have it burned at 8x? Will the difference be negligible? Please advise! Thanks... -todd amodeo http://bartlebymusic.com
https://soundcloud.com/user-496684376 |
Re: Burning at 1x with Nero
Nero simply lists all possible burn speeds for your burner with the media currently inserted. It appears that your CD burner cannot burn any lower then 8x speed. The best way to handle this is to burn multiple copies and test each copy to see which one has the fewest number of errors.
Christian |
Most burners today can't burn at true single speed, and most media today actually provide better results at higher speeds. For example, my latest batch of Taiyo Yuden media gives extraordinarily good results at 16x through my Plextor 716A.
My suggestion would be to burn a few discs at different speeds, then find a pal in your area with a plextor drive to perform some QC for you to determine which is the best to send to duplication. Don't forget to encode your ISRC's (not all burners can do this) and include a printout of all PQ subcode info accurate to the frame for your replicator.
Cavell Studios |
toddamo,
If you are really in need of that feature ( current drives and media burns high quality red book masters @ 4X ) I'd suggest to look up your drive's specifications. It should list all available burning speeds. Then update the firmware ( from manufacturers support page ) and install the latest ASPI driver .. good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Burning Audio CD with Nero & PTLE5.1 | Mike Emerson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-25-2002 12:47 AM |
Ahead Nero Burning Rom Software | mkosel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 10-24-2002 12:52 AM |
CD burning,Nero or CD creator5 | Valeri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-10-2002 08:27 PM |
NERO CD BURNING SOFTWARE & PRO-TOOLS LE | Brian West | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-30-2002 01:51 PM |
Anyone burning cd's with Nero | LabbRatt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-28-2002 04:22 PM |
