Old 03-26-2021, 08:55 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Pro Tools v2021.3 Now Available
Hi Carbon Users,
In case you missed it, yesterday we released Pro Tools 2021.R3. Go here for info.
Below is the list of Carbon fixes. Please note that there are a few issues with macOS 11.2 (Big Sur) that we expect to be resolved in macOS 11.3 once it's released. For workaround information on those macOS 11.2 issues, see the "Pro Tools | Carbon" section here.
  • Audio dropouts/artifacts in 10.15.7 and 11.2.3; Resolved in future Big Sur release (PT-268800)
  • No Audio Output over AVB; Resolved in future Big Sur release (PT-268662)
  • Unable to create Session at new Sample Rate; Resolved in future Big Sur release (PT-265729)
  • No Audio device in Audio Midi Setup; Resolved in future Big Sur release (PT-268874)
  • "Cannot Communicate with Playback Engine"; Resolved in future Big Sur release (PT-268881)
  • Delay compensation when using both hardware inserts and AAX Native plug-ins on the same track is now calculated correctly. (PT-268293)
  • Delay compensation for hardware inserts on DSP Mode-enabled tracks is now calculated correctly for bounced/committed audio. (PT-267502)
  • Fixed an issue where a hardware insert assignment could be deleted after restoring I/O settings from session. (PT-266606)
  • DSP Mode now works correctly for mix groups. (PT-268738)
  • The "DSP Mode has been automatically enabled..." dialog is no longer redundantly shown after freezing a track. (PT-268275)
  • Fixed a case where a dialog would incorrectly indicate that the clock source is not valid. (PT-267542)
  • The "Pro Tools can't communicate..." dialog now appears immediately after Pro Tools | Carbon is disconnected from the Mac. (PT-267393)
  • Fixed an issue where monitor output level would be louder when recording to DSP Mode-enabled tracks with count off enabled. (PT-270388)
  • Fixed an issue where line outputs 1-4 would be muted after disabling Alt 1 and Alt 2 monitors. (PT-269069)
  • Fixed an issue where Talkback Mic input could distort. (PTHW-218)
As you can see, there are a number of fixes for delay compensation with hardware inserts. I know some of you were running into problems here, so please let us know how things are working once you update.
Additionally, some of you are experiencing issues with noticeable fan noise on the unit. We are closely investigating this and will update you as soon as possible. Thank you very much for your patience on this.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 03-27-2021, 02:35 AM
darkwavo darkwavo is offline
Default Re: Pro Tools v2021.3 Now Available
Originally Posted by Kyle Splittgerber View Post
Hi Carbon Users,
Great news. Thanks so much.
Does this mean Pro Tools can run on a new M1/Big Sur Mac without Rosetta?
Planning on buying Carbon ASAP.
Thanks again !
Old 03-27-2021, 02:42 AM
Sardi Sardi is offline
Thanks again !
No.
It’s in the release notes.
Old 04-28-2021, 11:36 AM
Hi All,
I wanted to follow up and let you know that Big Sur 11.3 was released which resolves a few of the Carbon bugs I mentioned above. I encourage you to update if you are running into these bugs.
Thanks.
Kyle Splittgerber
Berkeley, CA
Old 04-29-2021, 07:40 AM
K Roche's Avatar
K Roche K Roche is online now
Good news ...........
System :
Enjoy the Journey
.... Kev...
Old 04-29-2021, 12:24 PM
dominicperry dominicperry is online now
Bad news for those of us who want to stay on 10.15.7..............
Dominic
Old 05-02-2021, 08:01 AM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Dominic
Yeah, having to be on the least compatible (and bleeding edge) OS to fix an issue doesn't really sound like a fix.
Old 05-02-2021, 10:16 AM
K Roche's Avatar
Dominic
Hummm are you sure ? According to this release info maybe not ?
https://avid.secure.force.com/pkb/ar...3-Release-Info
System Requirements and Compatibility with Pro Tools 2021.3 & 2021.3.1 Software
Windows 10 64-bit build 20H2
Windows Updates must uninstall previous versions before proceeding. More information HERE
macOS Big Sur (11.2.3), Catalina (10.15.7), macOS Mojave (10.14.6)
System :
Enjoy the Journey
.... Kev...
Old 05-02-2021, 10:31 AM
Whilst it's clearly good news that problems are fixed, it's bad news that things like audio dropouts on an interface require an OS update, given that there are good reasons to want to stay on earlier versions of PT, which mean staying on earlier versions of the OS.
Of course, Carbon features and functions, (as well as some fixes) are all being rolled into PT updates, which is a problem in itself, given that Carbon is so new - you can't go back before 2020.11 anyway if you want Carbon support.
If, as an example, you wanted to use an RME interface, you could chose whatever version of the OS you wanted and pick from a wide variety of RME drivers which go along with that OS. Then pick your version of PT to go with the OS. That level of flexibility isn't available with Carbon, which would be fine if:
(1) the only OS choices for Carbon weren't just 10.15.7 and 11.x and
(2) there weren't so many glaring bugs being introduced in the latest versions of PT.
Old 05-03-2021, 06:05 AM
dankin dankin is offline
Is Carbon solid for the people that have it? I’m really close to ordering one, but seeing things like “audio dropouts” just being fixed, makes me question it. Is that a rare issue, or do most people experience that? As much as I hate the workflow with the Apollos, I have had zero issues with them.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII
Pro Tools v2021.3 Now Available Avid Technical Alerts 0 03-25-2021 09:16 AM
FS: Pro Tools HD 8 + Pro Tools HD 9 + Pro Tools 9 Bundle iLOK license Delta Music Belgium Buy & Sell 1 02-27-2019 03:33 PM
